Need a new elec. radiator fan.................... #597015
01/29/10 02:05 AM
01/29/10 02:05 AM
State of confusion
Thumperdart Offline OP
State of confusion
I know there were some old posts about some chevy fan assembly that worked well and were a good price. Does anyone know the fan or how to visit old posts? Thankxx......my fan is a Griffen and measures 21"`s wide and 18"`s tall measured core to core(not tank to tank)and I have about 4 1/2"`s depth to work with.
Post deleted by Defbob [Re: Thumperdart] #597016
01/29/10 02:23 AM
01/29/10 02:23 AM
Re: Need a new elec. radiator fan.................... [Re: Thumperdart] #597017
01/29/10 02:26 AM
01/29/10 02:26 AM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
was an HHR fan- try these numbers,
rock auto.com p/n 15817306
or GM 3115200
Re: Need a new elec. radiator fan.................... [Re: 605ply] #597018
01/29/10 06:14 AM
01/29/10 06:14 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
as long as the fan can suck across the whole radiator it's not critical on what fan to use. my fans a cheap chinese knock off, with my homemade shroud it keeps my junk real cool.
Re: Need a new elec. radiator fan.................... [Re: rebel] #597019
01/29/10 07:06 AM
01/29/10 07:06 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
HHR
Re: Need a new elec. radiator fan.................... [Re: ProSport] #597020
01/29/10 08:49 AM
01/29/10 08:49 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I went with the HHR as MANY have stated how good it was and was dirt cheap also... cost me I believe $80 delivered with the connector I did cut into the core support like many recomended and gained .75 in clearance....
Mopar Performance
Re: Need a new elec. radiator fan.................... [Re: moparniac] #597021
01/29/10 08:54 AM
01/29/10 08:54 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
says only 1 remaining! better get it!
HHR Fan
Mopar Performance
Re: Need a new elec. radiator fan.................... [Re: moparniac] #597022
01/29/10 09:53 AM
01/29/10 09:53 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
HHR here and got it from Rockauto.com for about $55 shipped.
Re: Need a new elec. radiator fan.................... [Re: TheOtherDodge] #597023
01/29/10 12:27 PM
01/29/10 12:27 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Here is a link with all the spec's on the fan. Link is in the second post from the top....yes, it is a ford site, but the info is good. I just got my HHR fan for Christmas this year, can't wait to put it on the car.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Need a new elec. radiator fan.................... [Re: FlyFish] #597024
01/29/10 12:55 PM
01/29/10 12:55 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
I would very much reccomend this fan I had 3 other fans on my car which is street driven and none of them did near the job of the hhr fan. If you have 4.5 inches of depth you will be fine. Best 60 bucks I have ever spent on a car.
Re: Need a new elec. radiator fan.................... [Re: vttm] #597025
01/29/10 01:05 PM
01/29/10 01:05 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
HHR,,,got it from Eric,,,,
Re: Need a new elec. radiator fan................ [Re: 69CHARGERMD] #597026
01/29/10 02:09 PM
01/29/10 02:09 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I'm another HHR fan fan...
Re: Need a new elec. radiator fan.................... #597027
01/29/10 02:54 PM
01/29/10 02:54 PM
State of confusion
State of confusion
Thankxx guys.........I`ll get one a.s.a.p. as my fan is 10 years old and is gettin real noisy. Anyone have the dimensions handy?
Re: Need a new elec. radiator fan.................... [Re: Thumperdart] #597028
01/29/10 03:48 PM
01/29/10 03:48 PM
State of confusion
State of confusion
My buddy has a turbo mustang and runs the taurus fan............anyone else try one of these?
Re: Need a new elec. radiator fan.................... [Re: Thumperdart] #597029
01/29/10 03:55 PM
01/29/10 03:55 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: Need a new elec. radiator fan.................... [Re: Thumperdart] #597030
01/30/10 12:32 PM
01/30/10 12:32 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have the HHR fan now, but here is what I've tried and read on other boards.
Lincoln Fan = Most flow, largest
HHR = Smallest fan, medium flow
Taurs = Medium size, lowest flow
All flow more than most aftermarket set ups. I trimmed the back of the shroud on the HHR for a little more clearance.
Re: Need a new elec. radiator fan.................... [Re: Thumperdart] #597031
01/30/10 01:30 PM
01/30/10 01:30 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I've run the V6 Taurus fan for the last 6 years or so....great on the street (even in 110 degree heat), and flows tons of air on high. I've never heard that it flows less than the HRR...but I guess it's possible.
The fan is offset in the shroud too...which helps it clear the water pump pulley or elec WP motor. One draw back is it pulls quite a few amps (especially at startup)....I had to upgrade from my stock alt (only 36 amp) to run it.
Re: Need a new elec. radiator fan.................... [Re: Quicksilver440] #597032
01/30/10 01:44 PM
01/30/10 01:44 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
what quicksilver440 said. I bench tested a hhr and the Taurus fan side by side and i thought the tarus flowed more air. also the taurus fan has 2 fan speeds low/high mine is set on high. i am useing a 27.5x19 summit aluminum rad on my 73 big block dart and have never had it over heat. i payed 120 for mine off ebay with a life time warranty. also i had to go with the taurus fan with the offset. because i could not get the hhr fan to fit right. but for 55 dollers the hhr fan is hard to beat. here is a pick of the taurus fan on my 73 dart. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Need a new elec. radiator fan.................... [Re: Quicksilver440] #597033
01/30/10 01:45 PM
01/30/10 01:45 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Do these fans flow as much air as the spal twin set-up
Re: Need a new elec. radiator fan.................... [Re: mopar65] #597034
01/30/10 01:48 PM
01/30/10 01:48 PM
mopar65 Offline
mopar65  Offline
here is another pic thanks Mopar65
