Aluminum rod bearing clearance #596971
01/29/10 01:00 AM
01/29/10 01:00 AM
PA
W
w7smallblock Offline OP
W
PA
How much is to much on a 1.88 rod journal with a GRP aluminum rod max rpm of around 8500
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596972
01/29/10 01:06 AM
01/29/10 01:06 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
How much do you have and what kind and weight of oil are you running? What kind of main bearings do you run (1/2, 3/4 or full groove)? Is it 1/4 mile only?
I don't think you could go wrong with .0020", taking into consideration the expansion of the rod.
Re: Aluminum rod bearing clearance [Re: dodgeboy11] #596973
01/29/10 01:27 AM
01/29/10 01:27 AM
PA
W
W
PA
It's a new motor no oil choice yet just mocking everything up and checking clearances i have .0037 and have 1/2 groove mains
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596974
01/29/10 12:12 PM
01/29/10 12:12 PM
PA
W
W
PA
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596975
01/29/10 12:18 PM
01/29/10 12:18 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That sounds about right, .030-.040 rods and 003-.035 on the mains. That's what I have, and I run 5-50 weight Torco synthetic oil.
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596976
01/29/10 02:13 PM
01/29/10 02:13 PM
I take it this is drag race only motor, if that is so the clearances you have are more than adequate with any weight oil unless your heating the oil and running zero wieght oil.
Re: Aluminum rod bearing clearance [Re: Cab_Burge] #596977
01/29/10 06:58 PM
01/29/10 06:58 PM
PA
W
W
PA
Nobody else has an opinion? I'll bet if this was a 440source post there would be alot of opinions
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596978
01/29/10 09:09 PM
01/29/10 09:09 PM
Sue Offline
Sue  Offline
.003-.005 on the rods but side clearence id go .015-.020
Re: Aluminum rod bearing clearance [Re: camastomcat] #596979
01/29/10 09:12 PM
01/29/10 09:12 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Re: Aluminum rod bearing clearance [Re: jamesc] #596980
01/29/10 09:31 PM
01/29/10 09:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
ooops .003-.004 is what I meant.
Re: Aluminum rod bearing clearance [Re: camastomcat] #596981
01/29/10 09:47 PM
01/29/10 09:47 PM
jamesc Offline
jamesc  Offline
i know just having fun
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596982
01/29/10 11:32 PM
01/29/10 11:32 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Jim a 1.88 rod journal.Hold on I'll go to dads and see what clearance those rice burner rods should have.I didn't now you were building a civic now instead of your demon.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Aluminum rod bearing clearance [Re: bdaz smblk] #596983
01/30/10 12:07 AM
01/30/10 12:07 AM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
I was told, from a fellow, far far away ,
not mentioning any names , that it used to be a small block crank, but sat so long it rusted into Bolivian.
And that's why the hondazuki, or yamasaki rod size was needed.
Just messin' Jim, glad to see you are getting it together.
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596984
01/30/10 01:05 AM
01/30/10 01:05 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
3-4 thou rod to crank pin bearing clearance 005 thou if blower motor, side clearance is 2x stock steel not 15-20 more like 30-40 thou and 40-60 on blower motor. hope this helps
MOPAR OR NO CAR
Re: Aluminum rod bearing clearance [Re: hemigod426] #596985
01/30/10 10:22 AM
01/30/10 10:22 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
People tend to go too tight thinking alum will expand. You need to go looser, keep in mind the alum will expand in ALL directions. I agree with .003-.004.
Re: Aluminum rod bearing clearance [Re: hemigod426] #596986
01/30/10 10:31 AM
01/30/10 10:31 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Re: Aluminum rod bearing clearance [Re: RyanJ] #596987
01/30/10 11:07 AM
01/30/10 11:07 AM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
are these the heavy duty pathfinder rodbearings? .003 to .004 is good.side clearance on the rods is also pretty important on alum. rods too . it helps keep oil temps down and that is what kills the rods.
Re: Aluminum rod bearing clearance [Re: webemopes] #596988
01/30/10 12:01 PM
01/30/10 12:01 PM
PA
W
W
PA
Thanks for the info. Ronnie, Kenny, and Joe i hope this will be the fastest quad 4 in town with one W7 head on it.
Re: Aluminum rod bearing clearance [Re: w7smallblock] #596989
01/30/10 11:57 PM
01/30/10 11:57 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Now that's some funny stuff there,
Jim, if you need anything, just call. I need to get up your way to see what's new anyway.
Later
Re: Aluminum rod bearing clearance [Re: mopar_to_ya] #596990
01/31/10 01:34 PM
01/31/10 01:34 PM
PA
W
W
PA
Ronnie if this weather every breaks you'll have to stop over. I saw the pictures of the inside of Colby's dart trunk on the other post it looks real good. You should post some pictures under members projects.
See ya , Jim
