Re: Aluminum rod bearing clearance
[Re: w7smallblock]
#596974
01/29/10 12:12 PM
01/29/10 12:12 PM
Posts: 320 PA
w7smallblock
PA
[Re: w7smallblock]
#596975
01/29/10 12:18 PM
01/29/10 12:18 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
That sounds about right, .030-.040 rods and 003-.035 on the mains. That's what I have, and I run 5-50 weight Torco synthetic oil.
[Re: w7smallblock]
#596976
01/29/10 02:13 PM
01/29/10 02:13 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
I take it this is drag race only motor, if that is so the clearances you have are more than adequate with any weight oil unless your heating the oil and running zero wieght oil.
[Re: w7smallblock]
#596982
01/29/10 11:32 PM
01/29/10 11:32 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Jim a 1.88 rod journal.Hold on I'll go to dads and see what clearance those rice burner rods should have.I didn't now you were building a civic now instead of your demon.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#596983
01/30/10 12:07 AM
01/30/10 12:07 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
I was told, from a fellow, far far away , not mentioning any names , that it used to be a small block crank, but sat so long it rusted into Bolivian. And that's why the hondazuki, or yamasaki rod size was needed.
Just messin' Jim, glad to see you are getting it together.
[Re: hemigod426]
#596985
01/30/10 10:22 AM
01/30/10 10:22 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
People tend to go too tight thinking alum will expand. You need to go looser, keep in mind the alum will expand in ALL directions. I agree with .003-.004.
[Re: hemigod426]
#596986
01/30/10 10:31 AM
01/30/10 10:31 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
3-4 thou rod to crank pin bearing clearance 005 thou if blower motor, side clearance is 2x stock steel not 15-20 more like 30-40 thou and 40-60 on blower motor. hope this helps
[Re: w7smallblock]
#596989
01/30/10 11:57 PM
01/30/10 11:57 PM
mopar_to_ya
south central,Pa
i hope this will be the fastest quad 4 in town with one W7 head on it.
Now that's some funny stuff there, Jim, if you need anything, just call. I need to get up your way to see what's new anyway. Later
[Re: w7smallblock]
#596991
02/01/10 04:21 PM
02/01/10 04:21 PM
Posts: 48 Pa
W7_Scamp
Pa
This means that the shortblock is going together. When is the rest of it going to be finished? Are you still doing the Street legal deal? or is this going to be strictly race? By the way if you're bored tonight stop by We're puttin the Wedge together!
