Re: Reconditioning bolts
[Re: Scamp451]
#596884
01/28/10 11:11 PM
01/28/10 11:11 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Specifically bolts, nuts, and washers for steering and front brake drum brake hardware. Better off just buying new, or is there a do-it-yourself method by soaking in a solution or something? I was thinking a wire wheel, but that seems to polish them in a way. Not a show car, just a driver, but the hardware still has to be cleaned up.
Eastwood blackening agent looks really nice. It's basically a black phosphate.
To get the rust off check out this thread: https://board.moparts.org/ubbthreads/show...rue#Post5724264
[Re: Neil]
#596887
01/30/10 02:29 PM
01/30/10 02:29 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
we used a tumbler with sand. let it sit over night and they come out looking good.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: ademon]
#596892
01/30/10 10:33 PM
01/30/10 10:33 PM
Posts: 699 Manassas, VA USA
Scamp451
Manassas, VA USA
to blacken the hardware, use machinest tool black, $50 bottle will do all the hardware on the car.
What is the difference between machinist tool black and rustoleum? New to this process.
[Re: 1_WILD_RT]
#596893
01/30/10 10:40 PM
01/30/10 10:40 PM
Posts: 503 Sooner state
Slim Smitty
Sooner state
Wild_RT, did you do the parts in your pic with the tool blackening kit?
The link you provided says the blackening kit is for indoor use. How does this stuff hold up on cars?
65 Coronet
[Re: Slim Smitty]
#596894
01/31/10 12:01 AM
01/31/10 12:01 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
No they were done in Black Oxide... I used Tool Black on all the hardware on my Challenger... It holds up OK in this (California) enviroment but I doubt it would do well in a damp enviroment...
[Re: Slim Smitty]
#596895
01/31/10 12:23 AM
01/31/10 12:23 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I used it on a bunch of small hardware under the hood, carb hardware, hood latch, bolts for alt/p/s bracket ect.. holds up well in IL, i don't drive my car in the rain/ stored indoors. after you dip or brush the the part, rinse off good and spray down with wd-40 pat dry good to go.
[Re: Scamp451]
#596897
01/31/10 12:30 AM
01/31/10 12:30 AM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
I picked up a tumber and green triangle media from Harbor Freight, then some Rust Away, and then a phosphate kit from Eastwood. I have about a 100 bucks into this so I do know after paying 36 bucks today for some nuts and bolts that this is worth doing when theres spare time. The bolt reference manual is something extra but well worth having if you have a lot of hardware to identify. Also you can go to amk.com for bolt and nut pics of unidentified nuts and Bolts. Pour a few inches of the rust away into tumber. Pour entire contents of green triangle media into tumber. HF stocks therese. Add bolts and hardware. 1-2 1/2 lbs. max hardware weight. Tighten lid and shake, rattle for about 3-4 hours. Take out bolts nuts, hardware and wash off. Inspect. Ones with rust go back and do a little more. Wash with fresh water. Put on cookie sheet and dry at 180 for 15 minutes. Take selected clean bolts and harware and put into green solution first. If all at once, leave them in longer. Watch them turn black. When they're really black, pull em out using tongs. Never use bare hands into chemicals. Lay onto paper towels for about a half hour. Lightly wipe off dirty or uneven areas off with a small edge of paper towel. Lightly wipe off excess fluid on edges. Now its time to seal them using the gold colored phosphate sealer. Leave them in for 10-15 minutes if doing a batch all at once. Take out with tongs and lay on paper towels. Roll up parts in the paper towel covered and lay in a well ventilated area..outside if possible. This lets the sealer grab on and dry onto them. I wait 24-48 hours before I feel they are really sealed. Results...Looks just like you bought 50 bucks worth of new hardware. I don't recommend sand blasting original OEM bolts and hardware. You may remove the markings that help identify where they belong on the vehicle. Remember to always use rubber gloves, goggles and tongs when dealing with these chemicals. It is re usable so pour it back into the original container if you took any out. http://www.eastwood.com/metal-blackening-kit-with-diamond-clear.html
[Re: LimeliteAero]
#596903
01/31/10 04:06 PM
01/31/10 04:06 PM
Challenger 1
Cincinnati, Ohio
for the guys tumbling their nuts. once the rust is removed the corrosion has left pitting behind, no? what do you do about that? Im going with an AMK kit and will reuse original hardware where needed if its usable.
Here's some hardware I did with green piramids and water. These were done in short time(3-4 hours), they can be almost spotless if you leave them in overnight. I just paint the heads with a zinc spray and oil/antisieze on the threads. Holding up well in my car.
Did some heater clips and mounting nuts. Same deal here, honestly only a couple three hours in the vibrator. Actully 4.5 hours. Look at the time stamp on the pictures. Always in a hurry and I rush them. Not perfect but plenty good enough for me for my driver type cars.Clean and easy to do, I rinse them in my kitchen sink. lol Better than trying to do it by hand. Still wet from the rinse, dry em up and refinish any way you want.
[Re: car48nut]
#596905
01/31/10 04:59 PM
01/31/10 04:59 PM
Challenger 1
Cincinnati, Ohio
I have walnut shells crushed, I used these with a few bolts and nuts in a vibrator tumbler over night and it did next to nothing. should I have added water or some other chemical to the shells first? Thanks
Shells are for real delicate parts and no I don't think water would help.
[Re: cdp]
#596908
01/31/10 07:39 PM
01/31/10 07:39 PM
Posts: 17 ohio
ta340
ohio
here are restored underhood nuts, bolts and latches.
who did these for you and how long.
