Page 1 of 3 1 2 3
440 intake manifold #596756
01/28/10 08:50 PM
01/28/10 08:50 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
Looks like I have to go back to stock manifold on my 70RR to clear air grabber. (running eddy performer RPM) What is the best one to use? Lot of diffrent years with diffrent carb holes. thanks Brian
Re: 440 intake manifold [Re: stateroadhog] #596757
01/28/10 08:53 PM
01/28/10 08:53 PM
any one that is easily (cheaply) available w the carb pattern you need (square or spread bore)
Re: 440 intake manifold [Re: RapidRobert] #596758
01/29/10 08:16 AM
01/29/10 08:16 AM
scratchnfotraction Offline
what ya gonna do with that rpm intake????
Re: 440 intake manifold [Re: scratchnfotraction] #596759
01/29/10 09:17 AM
01/29/10 09:17 AM
Central NC
gch Offline
gch  Offline
Central NC
I believe the 70-71 intakes are the best.You may try the edelbrock ch4b to see if you have the clearance.I have one with hogged out bolt holes if you want to try it for fitment.Cover the shipping and it's yours.
Re: 440 intake manifold [Re: gch] #596760
01/29/10 10:09 AM
01/29/10 10:09 AM
Owosso, Michigan
Owosso, Michigan
Which holes are hogged out? So its not a usable intake? I will probably sell RPM. thanks Brian
Re: 440 intake manifold [Re: stateroadhog] #596761
01/29/10 10:27 AM
01/29/10 10:27 AM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
He means where the intake bolts to the heads, the holes are elongated or oversized. Someone may have had a hard time fitting it on their engine and opened up the bolt holes. Intake is still very usable! And that design is very similiar in size to the stock manifold....thus the offer to try that one.
Re: 440 intake manifold [Re: stateroadhog] #596762
01/29/10 10:50 AM
01/29/10 10:50 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Have you tried a CH4B Edelbrock? Almost the same height but much better in overall performance. There are still plenty out there for sale.
Re: 440 intake manifold [Re: stateroadhog] #596763
01/29/10 11:01 AM
01/29/10 11:01 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Get a CH4B intake. It wil work and is almost as good as the RPM.
Coming soon!!!!
Re: 440 intake manifold [Re: Mr.Yuck] #596764
01/29/10 12:10 PM
01/29/10 12:10 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Hood clearance...how about the Holley Street Dominator? Does not look like the factory dual plane but is available new AND used, is an excellent performer and is low enough to where you can dial in the exact carb position/height with a spacer.
Keep old mopars alive.
Re: 440 intake manifold [Re: Mr.Yuck] #596765
01/29/10 01:31 PM
01/29/10 01:31 PM
Owosso, Michigan
Owosso, Michigan
Thanks for all the great info. Now is that Edlebrock manifold cast with the CH4B in it or is there another number to go by? I have looked at all the usuall sites here, craigs list, e-bay, amazon. is there anyone that might have one of these manifolds for sale other than the one that gch has offered me?
Re: 440 intake manifold [Re: 2boltmain] #596766
01/29/10 04:05 PM
01/29/10 04:05 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I had to cut my aircleaner veloicty type base on my 383 in a N96 70 Bee. Then couldn't run a wingnut bcause it hit the hood.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 440 intake manifold [Re: stateroadhog] #596767
01/29/10 04:17 PM
01/29/10 04:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's just called the CH4B, no other name. It's a good intake and definitely the one you want.
Re: 440 intake manifold [Re: 2boltmain] #596768
01/29/10 07:35 PM
01/29/10 07:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Holley Street Dominator and it fit under my stock flat hood with room to spare. I thought the Holley SD was shorter then the Eddy intake ? I know the Street Dominator works good and has good low end for a single plane. Ron
Re: 440 intake manifold [Re: 383man] #596769
01/29/10 07:45 PM
01/29/10 07:45 PM
Manitoba, Canada
Manitoba, Canada
It is shorter than the RPM intake, but taller than the CH4B. I have heard from others as well that the SD is too tall for an air grabber setup.
Re: 440 intake manifold [Re: DaytonaTurbo] #596770
01/29/10 07:49 PM
01/29/10 07:49 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
YOU GUYZ and your CH4B !
IF that intake is superior to most intakes out there ... THEN WHY didn't Eddy repop that intake AS-IS .. just like it was produced back in the 60's ?
Re: 440 intake manifold [Re: DaytonaTurbo] #596771
01/29/10 07:54 PM
01/29/10 07:54 PM
Rug_Trucker Offline
Rug_Trucker  Offline
IT IS SHORTER
IT DOES The air cleaner has a velocity stack built into the base. I had to shorten mine. Cut it,welded a plate, cut a hole for the carb. If you want it to seal with the duct work that's what you do. Or store the stock air cleaner.
Re: 440 intake manifold [Re: stateroadhog] #596772
01/29/10 07:55 PM
01/29/10 07:55 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
CH4B...even has a Chrysler part # on it (as an aluminum replacement for the cast iron stocker....
1MYTGTX
Re: 440 intake manifold [Re: dOrk !] #596773
01/29/10 08:00 PM
01/29/10 08:00 PM
Rug_Trucker Offline
Rug_Trucker  Offline
I think it is a little bit better than stock. Where is that manifold test that MM did? The stocker went to 500 didn't it?
Re: 440 intake manifold [Re: 1MYTGTX] #596774
01/29/10 08:05 PM
01/29/10 08:05 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The CH4B is about .4 taller than the stock intake, and the SD is about .9 taller than stock. The CH4B is a nice improvement over stock cast iron hp intake
Re: 440 intake manifold [Re: Rug_Trucker] #596775
01/29/10 08:06 PM
01/29/10 08:06 PM
Rug_Trucker Offline
Rug_Trucker  Offline
I don't think all of them had Chrysler numbers on them.
What did you run on you BB's when you were racing back then Doc?
Page 1 of 3 1 2 3
