Building a 340 - Various Buildup Questions #59594
05/19/08 01:19 PM
05/19/08 01:19 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I heard back from my machine shop today and the 340 block I dropped off is ready for the stroker build. I saw a couple of different kits from Mancini for about 2K. My question is should I go internally or externally balanced? This is going in my '68 'cuda w/ had a 4 spd tranny.
Also, any recommendation on heads? I was leaning toward the Edelbrock 340 heads using something like a Comp XE280 cam.
I am building a nice street motor that may see a pass or two down the track so I don't want to go too radical.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Building a 416 Stroker - Kit question [Re: Erik] #59595
05/19/08 01:27 PM
05/19/08 01:27 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Don't get the Edelbrock "340" heads. Get the Edelbrock closed chamber 63cc LA engine heads and build a quench combustion chamber engine. I am building a 414" (340 block .020" over) stroker. I ordered the Scat cast crank kit with the KB745 forged step dish pistons:
1-98013BI
It comes internally balanced and Summit's price right now is $1279 plus $11 handling and free shipping. Scat says they guarantee the bearing clearances and balance. Mine will be getting checked out by a local shop. Should be few more weeks before it arrives.
I am building mine as a street engine for pump gas.
Re: Building a 416 Stroker - Kit question [Re: 69Cuda340S] #59596
05/19/08 02:42 PM
05/19/08 02:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Dan at performance only racing can get you a real good deal on the same kit plus you will be suporting a moparts member and someone who knows about mopars.
Re: Building a 416 Stroker - Kit question [Re: Erik] #59597
05/19/08 03:55 PM
05/19/08 03:55 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Thanks!
I used the Mancini kit for my 416. It is a high quality kit that uses a Callies crank. I got the one that was already balanced. I also have Eddy heads that were ported by RyanJ at Shady Dell speedshop. It's agreat combo that's hard to beat. I have a small solid street roller and 11.5-1 compression and my motor made about 540 HP with a Perf RPM Airgap/950 Holley and just under 500 with a six pak. -Bob
Re: Building a 416 Stroker - Kit question [Re: BobR] #59598
05/19/08 04:00 PM
05/19/08 04:00 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Excellent!
Re: Building a 416 Stroker - Kit question [Re: Erik] #59599
05/19/08 04:13 PM
05/19/08 04:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
erik , do an internal balance engine .
Re: Building a 416 Stroker - Kit question [Re: JohnRR] #59600
05/19/08 04:18 PM
05/19/08 04:18 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. I am going to discuss my options w/ my machine shop tomorrow.
Re: Building a 416 Stroker - Kit question [Re: Erik] #59601
05/20/08 01:24 PM
05/20/08 01:24 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
After a discussion w/ my machine shop, this is what we decided to do:
Bore the block to 30 over and deck it
Use the stock forged 340 crank I already have
new Eagle rods
new TRW pistons
Edelbrock 340 heads
Edelbrock Performer RPM Airgap intake
Comp Cam 280 mechanical cam/lifters
750-800 cfm carb (undecided on type)
10.5:1 copression ratio
He feels I should be able to get 400 - 450 hp out of it.
What do you all think?
Re: Building a 416 Stroker - Kit question [Re: Erik] #59602
05/20/08 01:27 PM
05/20/08 01:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"He feels I should be able to get 400 - 450 hp out of it.
What do you all think?"
Closer to 400 than 450. -Bob
Re: Building a 416 Stroker - Kit question [Re: BobR] #59603
05/20/08 02:11 PM
05/20/08 02:11 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
400 is still good for me.
He is trying to push me to a mechanical cam. Since the car will only see occasional passes, would a hydraulic setup be better for my needs?
Re: Building a 416 Stroker - Kit question [Re: BobR] #59604
05/20/08 02:15 PM
05/20/08 02:15 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
Erik, I would go stroker. When I had my 417 built I told the builder I wanted a fun street motor and something that was going to be reliable. Here is what he built me:
340 block (0.035 over)
Eagle 4" crank
reconditioned stock rods
custom forged venolia pistons
9.5:1 compression (very pump friendly)
stock 'X' heads with 2.02 valves. (heads were cleaned up and good valve job done)
Mopar Performance 484 cam (241int/241ext, .484int/.484ext 108lsa)
Edelbrock Airgap intake
Holley 770 vacuum Secondary Street Avenger Carb
FBO ignition system
FBO curved distributor
On a chassis dyno the car made 375 peak RWHP and 484 peak RWTQ. At the flywheel the peak numbers are 420HP and 537HP respectively.
If you go through my build you can see that it is quite conservative. If I were to swap the heads for some Edelbrocks and put another cam with higher lift I could squeeze a fair amount more HP out of it but for my purposes this engine is good enough for the street and fun to drive as well as reliable. It also has a nice mean idle sound to it.
Unless there is a huge cost difference go stroker.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Building a 416 Stroker - Kit question [Re: Erik] #59605
05/20/08 02:21 PM
05/20/08 02:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Sounds like a chevyguy building a mopar
Eagle rods are junk compared to an equivalant SCAT rod. Also for the pistons there are way better choices out there for about the same money. TRW pistons are very heavy 40 year old desighns and that cam is really going to want to turn some rpm. I would say at least 6500-7000 shift points. The SCAT rods are mede of 4340 steel instead of 5340 in the eagle, the scats also use cap screws instead of a nut and bolt like eagles and stock rods. I am not sure about the eagles but I know the SCAT rods use arp bolts and the are a lot less likely to need resizeing.
I would get a flat top piston and run the closed chamber eddy heads. That way you can take advantage of quench and not get a bunch of crevice volume. The price is about the same so why not do it better?
I do think it will make closer to 450 with good machine work though. Good cam and intake choice. Either way will make similar HP but durability will be way better and it will rev a lot quicker witch makes it feel more powerfull .
The differance in the stroker kits and what you are doing is almost none and will make you very very happy!
Re: Building a 416 Stroker - Kit question [Re: HotRodDave] #59606
05/20/08 02:31 PM
05/20/08 02:31 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Funny you say that. He feels that the Scat products are garbage. He helped me build the stock 340 I had in my Chally 'vert. and is rally a Mopar guy trying to make a living in a Chevy world......
So you are saying I should go for the standard 318-360 RPM heads and not the 340 heads? We are running flat top pistons. What type of piston do recommend over the TRWs?
Re: Building a 416 Stroker - Kit question [Re: Erik] #59607
05/21/08 08:22 AM
05/21/08 08:22 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Re: Building a 416 Stroker - Kit question [Re: Erik] #59608
05/21/08 08:53 AM
05/21/08 08:53 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yes, get the closed chamber 63cc heads and get a piston that sits at zero deck for a quench combustion chamber.
Re: Building a 416 Stroker - Kit question [Re: 69Cuda340S] #59609
05/21/08 09:02 AM
05/21/08 09:02 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Ther 340 will still make good hp but the torque wont be any were near as good as it would be be with the 4" arm.
Re: Building a 416 Stroker - Kit question [Re: AdamR] #59610
05/21/08 09:44 AM
05/21/08 09:44 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd go stroker for sure for a street engine, stock stroke engines can make good power on paper and on the dyno (especially in the upper RPM ranges) but in real world street driving low RPM torque is where the fun is, strokers feel like a big blocks off idle, a joy to drive on the street. I've done allot of research on cranks recently, I agree with many of the above posts, go internally balanced, buy the best crank and rods you can afford, and use the lightest pistons you can afford (I like Scat or Callies cranks, Scat, Manley($), or Carillo($$$) rods, and Diamond pistons). Air gap intake with a good carb of choice.
Hydraulic cams are also great for street driving, same reason, zero valve adjustments, similar power, especially in the lower RPM ranges. A solid or roller cam will ultimately allow higher RPMs and more power, but on the street you'll rarely need either.
I don't see the need for you to buy EB heads if you want to make around 450HP, a good valve job and mild port work on some X or J heads will get you there with the right combo, plus iron heads make more power than aluminum all things being equal. If you want some free HP from iron heads the 308 heads are awesome, you can approach W2 numbers with them with very little work. Aluminum has it's advantages (ease of porting and easier to repair if they get hurt, etc.) but for a budget build iron heads are pretty hard to beat.
Re: Building a 416 Stroker - Kit question [Re: AdamR] #59611
05/21/08 09:49 AM
05/21/08 09:49 AM
dogdays Offline
dogdays  Offline
Scat rods are better than Eagle rods, especially the SIR.
DO NOT use the 340 Edelbrock head! Use the closed chamber Edelbrock head. The only thing the 340 head will get you is lack of squish. Build the engine for pistons at deck level (zero deck).
TRW pistons aren't sold any more. They are now called Speed-Pro. They are heavy, 720 grams without the pin. This is a bigblock piston weight.
This is exactly the wrong piston to use in an engine built for acceleration.
You should be able to find a lightweight custom forging that weighs around 200 grams less and doesn't cost a bunch more. If you are not building a stroker then the 340 needs to rev to make power. Lightening up the pistons allows quicker engine acceleration and puts less stress on the reciprocating parts, bearings and crankshaft.
Sounds to me that your engine guy is stuck in a time warp (without Susan Sarandon prancing around).
R.
Re: Building a 416 Stroker - Kit question [Re: dogdays] #59612
05/21/08 09:54 AM
05/21/08 09:54 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Start running some cost numbers and you will find it just doesn't make sense not to build a stroker. Especially if you can afford the Edelbrock heads.
Re: Building a 416 Stroker - Kit question [Re: 69Cuda340S] #59613
05/21/08 10:07 AM
05/21/08 10:07 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks for the replies everyone!
I already have a good 340 forged crank, so why spend $$ on a new crank? That is why I am not going the stroker route.
For the build, the block and the crank are the only parts I have to start with. I will look into different pistons & rods. As far as heads go, I don't have any right now so that is why I would go the Edelbrock route. If I could find a nice set of X heads, I would consider them also. I don't see too many of them around.
I think I'll stick w/ a hydraulic cam. I don't want to have to keep adjusting it. What do you think of the Comp Cam Magnum 280?
