Anyone using this oil in their flat tappet motors? #595213
01/26/10 11:52 PM
01/26/10 11:52 PM
In a town not near you.
clownzilla Offline OP
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Anyone using this oil in their flat tappet motors? [Re: clownzilla] #595214
01/27/10 04:03 AM
01/27/10 04:03 AM
IL
knyech1 Offline
knyech1  Offline
IL
Seems decent. I am going to use Joe Gibbs to break in then either the same brand or Amsoil flat tappet after that.
Re: Anyone using this oil in their flat tappet motors? [Re: knyech1] #595215
01/27/10 04:06 AM
01/27/10 04:06 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Not yet but with 1800 PPM of z/p it should be a winner.
Leave the gun.......take the Cannoli's....Mike
Re: Anyone using this oil in their flat tappet motors? [Re: mike s] #595216
01/27/10 07:51 AM
01/27/10 07:51 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
I used Torco Racing Oil in my flat tappet race motor
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Anyone using this oil in their flat tappet motors? [Re: Georg] #595217
01/27/10 08:56 AM
01/27/10 08:56 AM
What weight oil do you normally run in spring/summer for the street?
I was running SAE-30 weight with Hughes high pressure additive, but would love to just use a good oil with no mix additive because I've heard alot of mixed reports on mixing stuff to the right additive mixture with different oils.
Hughes claims their stuff mixes with any oil, but they don't really recommend what oil brand/weight/type to mix it with.
Re: Anyone using this oil in their flat tappet motors? [Re: clownzilla] #595218
01/27/10 09:56 AM
01/27/10 09:56 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Don't a couple of cam companies offer a special process that makes the cam and lifters BULLETproof and eliminates the need for any of this special oil or additives ?
Re: Anyone using this oil in their flat tappet motors? [Re: clownzilla] #595219
01/27/10 10:54 AM
01/27/10 10:54 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We are now suggesting the Joe Gibbs Driven oil with all of our cams. We still offer the additive but their good enough oils now that we feel one of them is the way to go.
Kevin
Re: Anyone using this oil in their flat tappet motors? [Re: Hughes] #595220
01/27/10 02:00 PM
01/27/10 02:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...is GM EOS and regular 10w30 a satisfactory combination?
I have access to a large quantity of GM EOS.
Re: Anyone using this oil in their flat tappet motors? [Re: Hughes] #595221
01/27/10 04:02 PM
01/27/10 04:02 PM
Kevin
Thanks for that, Hughes.
Re: Anyone using this oil in their flat tappet motors? [Re: dOc !] #595222
01/27/10 05:03 PM
01/27/10 05:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
BULLET proof? No. More wear resistant? Yes.
Re: Anyone using this oil in their flat tappet motors? [Re: can.al] #595223
01/28/10 03:58 PM
01/28/10 03:58 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
In the right oil that would probably be fine. Part of the problem is all of the detergents the newer oils have in them. These detergents fight the Additives for space on the metal. You really need to look at switching to one of the newer, Not for street use oils like Joe Gibbs Driven.
Kevin @ Hughes
Re: Anyone using this oil in their flat tappet motors? [Re: can.al] #595224
01/28/10 07:16 PM
01/28/10 07:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The new EOS is re formulated think the zinc is gone!
Re: Anyone using this oil in their flat tappet motors? [Re: Hughes] #595225
01/28/10 08:55 PM
01/28/10 08:55 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Kevin
Which version of Joe Gibbs oil do you recommend? They all seem to be called "Driven."
http://www.joegibbsracingoil.com/products/engineoils.html
Re: Anyone using this oil in their flat tappet motors? [Re: topbrent] #595226
01/28/10 09:53 PM
01/28/10 09:53 PM
I was wondering the same thing.
I'm thinking the hot rod stuff, lotsa zinc.
Re: Anyone using this oil in their flat tappet motors? [Re: clownzilla] #595227
01/29/10 12:36 AM
01/29/10 12:36 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
The hot rod oil is good for something that doesn't get driven a lot. Rust inhibitors and all that. Call Gibbs and give them your application and they can give you their recommendation. They do make the oil after all.
Re: Anyone using this oil in their flat tappet motors? [Re: topbrent] #595228
02/02/10 02:45 PM
02/02/10 02:45 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We like the Break-In oil for break-in and the 10W30 HotRod Oil for everyday use. Either Conventional or synthetic. The XP3 racing oil is good for full time racers or cars that get run really hard.
Kevin@Hughes
Re: Anyone using this oil in their flat tappet motors? [Re: dOc !] #595229
02/02/10 04:49 PM
02/02/10 04:49 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
It's a special prosess they nitrate the cam Makes it hard, costs more.I think you still need to breakin the cam
