Page 1 of 3 1 2 3
E-body washer hose routing ?? #59500
05/19/08 11:33 AM
05/19/08 11:33 AM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Does anyone have a diagram or can they shoot me a
few pics of how the hoses route along the apron
and up under the hood for a car with an electric
pump unit?
Re: E-body washer hose routing ?? [Re: BADBEE] #59501
05/19/08 01:39 PM
05/19/08 01:39 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
I'll try to post a pic or two when I get home.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59502
05/19/08 03:02 PM
05/19/08 03:02 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Thanks.
Re: E-body washer hose routing ?? [Re: BADBEE] #59503
05/19/08 07:00 PM
05/19/08 07:00 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Here's mine. I'm not saying for certain it is absolutely correct, but might stimulate some helpful discussion.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59504
05/19/08 07:06 PM
05/19/08 07:06 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
One more showing it a little closer to the bottle. Ok,.that one didn't turn out so I took this one.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59505
05/19/08 07:25 PM
05/19/08 07:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I had someone else tell me the drivers side end should route thru the master cylinder/power brake booster wire clip on that end then up to the hood tee
Re: E-body washer hose routing ?? [Re: gtx6970] #59506
05/19/08 07:32 PM
05/19/08 07:32 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Bill, if that's true I need a lot more hose. Do you sell it? By the way, thank you VERY much. I appreciate you.
Re: E-body washer hose routing ?? [Re: gtx6970] #59507
05/19/08 07:36 PM
05/19/08 07:36 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hi Bill,
I heard that also. Do you know where can I get the "master cylinder/power brake booster wire clip"? Thanks.
Re: E-body washer hose routing ?? [Re: rayztoy] #59508
05/19/08 08:11 PM
05/19/08 08:11 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
I'd like to see a picture if anyone has one.
Re: E-body washer hose routing ?? [Re: gtx6970] #59509
05/19/08 08:21 PM
05/19/08 08:21 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Amazing how an unchallenged lie can become the absolute truth.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59510
05/19/08 08:24 PM
05/19/08 08:24 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
I just looked at an atricle called "Anatomy Of a Solid Gold "Cuda from Mopar Action; it was on a Gibson restored 6 pack Cuda and the washer hose was routed like mine. Again, I'm not saying it's right, but it is food for thought.
Re: E-body washer hose routing ?? [Re: beepbeep] #59511
05/19/08 08:28 PM
05/19/08 08:28 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
I was typing while you were posting. That's a very interseting pic there Beep. Thanks for your imput. What would the rational be for draping it across the back of the engine.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59512
05/19/08 08:32 PM
05/19/08 08:32 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
I guess there is always some variation. Mine is run like yours Ron, and goes through a hole in the cowl.
Re: E-body washer hose routing ?? [Re: rayztoy] #59513
05/19/08 08:36 PM
05/19/08 08:36 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Yep, like most things Mopar, there are very few absolutes, but I don't think it runs through hole in the cowl.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59514
05/19/08 08:44 PM
05/19/08 08:44 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
There's a lip where the top of the cowl meets and overhangs on the firewall about a 1/2 inch and there is a hole right above my wiper motor. It was suggested that the hose runs through it.
Re: E-body washer hose routing ?? [Re: rayztoy] #59515
05/19/08 08:46 PM
05/19/08 08:46 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
That's seems logical, but I don't think so.
Re: E-body washer hose routing ?? [Re: 70challrtse] #59516
05/19/08 10:17 PM
05/19/08 10:17 PM
Ont, Canada
gygeneral Online content
gygeneral  Online Content
Ont, Canada
There was an engineering drawing on BW's site showing the routing through the wire holder on the master cylinder. When I did mine, the hose lenght in the kit was not long enough to be able to do this.
Re: E-body washer hose routing ?? [Re: gygeneral] #59517
05/19/08 11:21 PM
05/19/08 11:21 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
I guess that is as good a reason as any to change history.
Re: E-body washer hose routing ?? [Re: beepbeep] #59518
05/19/08 11:43 PM
05/19/08 11:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
beepbeep showed the routing at the booster for the variable speed wiper motor (with power washer)above.
If any of the car owners with the two speed motor (manual washer MOST of the time) needs it, here is a photo for you;
Re: E-body washer hose routing ?? [Re: rayztoy] #59519
05/20/08 07:27 AM
05/20/08 07:27 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Page 1 of 3 1 2 3
