Pro Shifting and Faceplating #594722
01/26/10 06:36 PM
01/26/10 06:36 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I know this stuff is out there on this website but I couldn't get any search results. I was wondering what exactly is "pro shifting" and "faceplating"? I put quotes because I know they are two different things. Is pro shifting another term for slick shifting where every other tooth on the gears are cut off so it can be slammed into gear without the clutch? And faceplating, is that just a hardening process? And where to send/how much does it cost/what kind of abuse can the resulting product have?
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Pro Shifting and Faceplating [Re: knyech1] #594723
01/26/10 06:54 PM
01/26/10 06:54 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Pro shifting involves replacing the engagment teeth with larger, stronger teeth that are spaced farther apart called "lugs". The brass, the dogs, and the springs are removed from the slider and 2 out of every 3 splines is removed from it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Pro Shifting and Faceplating [Re: Hemi_Joel] #594724
01/26/10 07:16 PM
01/26/10 07:16 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
So what benefit is there from pro shifting? Was I correct in the clutchless shifting from 1-2? And faceplating 3-4 what does that do?
Re: Pro Shifting and Faceplating [Re: knyech1] #594725
01/26/10 07:30 PM
01/26/10 07:30 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
With a pro shifted trans, the sliders have that wide gap for the lugs to fit into. SO you can slam the gears hard and fast at wide open throttle without missing a shift. You still should use the clutch, but just barely tap it to unload the gears.
Like this:
http://www.youtube.com/watch?v=uu94rcdWFyM
Re: Pro Shifting and Faceplating [Re: Hemi_Joel] #594726
01/26/10 09:27 PM
01/26/10 09:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You still have to use the clutch or you'll round off the lugs and the slider. Contact Liberty Gears www.libertygears.com for more info. You also need to use the clutch for face plated gears. You can buy a trans that you do not have to use a clutch for about $8000.
Re: Pro Shifting and Faceplating [Re: knyech1] #594727
01/26/10 10:18 PM
01/26/10 10:18 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Here is the Liberty Face-plate in my Richmond box.
Gus
64 Plymouth Savoy
Dana 60
Re: Pro Shifting and Faceplating [Re: fourgearsavoy] #594728
01/26/10 10:28 PM
01/26/10 10:28 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I've heard about Liberty's Pro Shifting setup for years, Faceplating is something I've only heard about in the last few years.
What setup is best for a street/strip 18 spline 4 speed for longevity and should it be done to all 4 gears?
Re: Pro Shifting and Faceplating [Re: KillerBee] #594729
01/26/10 10:34 PM
01/26/10 10:34 PM
Rittman Ohio
Rittman Ohio
I would Pro-shift second then Faceplate third and fourth.Second gear Pro-Rings seem to outlast 3-4 a few seasons longer.
Gus
64 Plymouth Savoy
Dana 60
Re: Pro Shifting and Faceplating [Re: fourgearsavoy] #594730
01/26/10 11:02 PM
01/26/10 11:02 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Gus
Any idea what having that done to my 18 spline 4 speed would cost?
Re: Pro Shifting and Faceplating [Re: KillerBee] #594731
01/27/10 12:10 AM
01/27/10 12:10 AM
Rittman Ohio
Rittman Ohio
I think its about $75.00 per gear to add a ring and they will need your side cover to modify the shift selector as well.Last time I talked Paul at Liberty it seemed like a pretty easy mod to the side cover and I'm pretty sure the 3-4 slider is $50.00.They can Pro-shift your existing 1-2 slider or you can get a new one from them,not sure on the price of that I never had to buy one from them.
If you need the work done send me a PM.I can set it up for you
Gus
64 Plymouth Savoy
Dana 60
Re: Pro Shifting and Faceplating [Re: fourgearsavoy] #594732
01/27/10 12:29 AM
01/27/10 12:29 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Gus
Thanks gus.
I'm over in Massillon.
The tranny is currently in a running/driving car but I plan to remove the engine/tranny this spring so I'm strongly thinking of getting this done.
Re: Pro Shifting and Faceplating [Re: KillerBee] #594733
01/27/10 09:05 AM
01/27/10 09:05 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
When I talked them the other day, they said they were working on having a faceplated 2nd in a few months. So if you wait til then you will be able to get 2nd faceplated as well, instead of getting it proshifted.
They quoted me around $400 for everything.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Pro Shifting and Faceplating [Re: DemonDust] #594734
01/27/10 09:34 AM
01/27/10 09:34 AM
Connecticut
5126brl No more Offline
Connecticut
I heard that 2 years ago then last year! Just pro shift second and faceplate 3-4. I do not use second on the street. The faceplating is awesome!
Re: Pro Shifting and Faceplating [Re: 5126brl No more] #594735
01/27/10 10:36 AM
01/27/10 10:36 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Prices I got from them for face plating were $80 per gear ,$100 for 3-4 slider $39 for new 3-4 modified syle fork . I was not aware about them requiring the side cover may be this new fork gets around that ?? As others have said they are still woking on the 2 gear but was told ,they were intending to be able to use your existing 1-2 steel fork . The 1-2 slider would be the same on both ends therefore I guess 1 gear would need the faceplate mod as well {unsure of this } .
Re: Pro Shifting and Faceplating [Re: RTshaker] #594736
01/27/10 10:53 AM
01/27/10 10:53 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I have only powershifted stock style A-833 transmissions and some other stock transmissions too. In a sub 600hp, sub 9 second car, is there really much to be gained from pro shifting or face plating? You still have to drive it the same way as powershifting a regular brass syncro trans, correct? It's either in the gear or not. And if you hit the gears 95% of the time with a stock A-833, will you hit it more with the Pro shift or face plate style? Is it any stronger?
I love being able to drive my trans 100% normally on the street and be able to powershift it at the track with no issues. I'm just trying to see the benefit in Pro Shifting or faceplating, if you now can't drive it that easily on the street. What is the performance gain?
Educate me.
Re: Pro Shifting and Faceplating [Re: LAR_414] #594737
01/27/10 11:27 AM
01/27/10 11:27 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Re: Pro Shifting and Faceplating [Re: gsmopar] #594738
01/27/10 12:05 PM
01/27/10 12:05 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
What about "dog boxes?"
Impressive video. I wonder how the transmission would shift behind a high torque/ higher rpm engine? Also, I wonder how long it would last? In the video he is not shifting a transmission behind an 11 second or faster car. It does look like a nice unit for the street that I would like to try. Track testing still needs done.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Pro Shifting and Faceplating [Re: 68LAR] #594739
01/27/10 11:26 PM
01/27/10 11:26 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
There is lots of videos on Youtube, several from companies pushing their product. One even states that it has over 20k km on it's shop car (turbo import thingey). ehhh.... I don't know, just thought it was pretty cool.
Now if it did work: I'd use a hydraulic clutch with a line lock on both the clutch and front brakes. Stage the car, flip a switch, mash the gas and launch on a button!
Re: Pro Shifting and Faceplating [Re: gsmopar] #594740
01/28/10 04:51 AM
01/28/10 04:51 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
http://www.youtube.com/watch?v=OI2fGeL7DEE
Looks interesting ..........
Re: Pro Shifting and Faceplating [Re: MrFoFody] #594741
01/28/10 08:56 AM
01/28/10 08:56 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Very intresting
