Question for you painters out there. #594409
01/26/10 12:25 PM
01/26/10 12:25 PM
Northern VA
1970440six Offline OP
Northern VA
I am fixing to paint the K frame and control arms on my 70 Roadrunner. The guy at the paint store sold me Dupont products. First I was sold a self etching primer to apply because I am working with bare metal. It is Dupont VariPrime 615S and mixes 1:1 with VariPrime 616S.
When I asked the paint guy if this primer would fill the rust divets, he said no I would need A primer filler and he sold me Dupont Chromasurfacer 7704S 2K primer-filler and ChromaBase 7775S activator-reducer and they get mixed 4:1. I spent quite a bit of money on these products.
I am looking at buying the Bill Hirsch Super Black Chassis undercarriage paint for the K frame and spray cans of Seymour's stainless steel and alumablast paint for control arms. I am buying these products from TP tools. I also bought the "Quasimolene" from Restorations by Rick for the lower control arms, which label says it is a PPG urethane formulation and needs to be reduced with DT-870 (whatever that is?).
Now for my question, will the above mentioned paints adhere to the Dupont primer filler I bought. I have asked all of these companies (except Resto by Rick) and the answer is we can't gaurantee that it will adhere. I realize they have to cover their butts in case it doesn't but somebody has to know if it will stick or not.
Re: Question for you painters out there. [Re: 1970440six] #594410
01/26/10 12:32 PM
01/26/10 12:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No I don't think you will have a problem.
I have used plenty of the Dupont varaprime and PPG DP and K-36 primers togeather with no problems. DT 870 is a PPG reducer.
I'm not sure about the black you selected for the K, but the paint that get's reduced with DT 870 won't be a problem over dupont primers
These products in this picture do not go togeather.
I can still get some lacquer colors BTW
Re: Question for you painters out there. [Re: 1970440six] #594411
01/26/10 12:48 PM
01/26/10 12:48 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
My concern would be the spray can paint. Many times the solvents will cause failure (wrinkling or blistering) of the primer/surfacer.
Re: Question for you painters out there. [Re: 1970440six] #594412
01/26/10 02:50 PM
01/26/10 02:50 PM
Jacksonville Florida
elitecustombody Offline
you should have no problems with using rattle can stuff over cured primers, just don't try to spray catalized materials over rattle can paint, that's where you might end up with problems
Re: Question for you painters out there. [Re: elitecustombody] #594413
01/26/10 06:56 PM
01/26/10 06:56 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Ok....everything has been said.....
You could have used the Nason primer for that job, comes in a quart and less expensive.
Dan
