I am getting ready to start the same project in a 71 chally. There is lots to do. Save the motor with every thing on it, belts hoses,alternator, every thing. Save the wire harnes, computer, I am even using the trany, and saved the drive shaft. You will probably want to get headers, and a mini starter. You will need motor mounts, oil filter relocater kit, electric fuel pump, and I've been told that a low presure ps pump will be needed. I sent my wire harness to street and performance, and they stripped off all unnecessary junk, [air bags, abs, and so on.] They also labeled all ends, and it came back with a S&P computer. There is lots of info out there on this swap. I did not find any info on how to make the electronic gas pedal work or how to make the speedo work with this trany,[trucks do not have the spedo sender in the trany].
