Re: BB Waterpump part numbers
[Re: SPWC]
#59311
05/18/08 07:53 PM
05/18/08 07:53 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The impeller in the pump can have 6 or 8 vanes, 6-vane pumps are generally used with A/C where the pump is driven faster than crank speed; a '65 would most likely use the 8-vane pump.
[Re: stumpy]
#59316
05/18/08 11:44 PM
05/18/08 11:44 PM
Posts: 4,102 Cochise County Arizona
SPWC
over 8 bucks ???
The money part isnt an issue. I was told that a BB water pump is a BB Water pump,and that they ALL interchange --PERIOD
Obviously that MAY not be the case.
[Re: SPWC]
#59317
05/18/08 11:51 PM
05/18/08 11:51 PM
they ALL should interchange.. there may be some oddball exceptions though.
[Re: SPWC]
#59318
05/19/08 09:47 AM
05/19/08 09:47 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
over 8 bucks ???
the difference is the blade count .
i just find it funny that you are over 8 bucks , if it were 30 - 50 bucks , yes , but 8 ????
have them get both and compare them ???? oh , that would be too easy
[Re: JohnRR]
#59319
05/19/08 11:13 AM
05/19/08 11:13 AM
SPWC
Im not over 8 bucks. I saw the part numbers awee different so I figured the parts were totally different. So JOHN RR, tell me how I am supposed to compare the 2 parts side by side when noone locally has them in stock and they have to be ordered When I order them they have to be prepaid!! Not as easy as you think!!
[Re: SPWC]
#59320
05/19/08 11:19 AM
05/19/08 11:19 AM
yah it is easy.. order the 8 or 6 blade impeller one call it a day. getting a waterpump shouldn't be a Jerry Springer show.
[Re: SPWC]
#59321
05/19/08 12:00 PM
05/19/08 12:00 PM
JohnRR
it's easier than you're making it out to be .
[Re: SPWC]
#59323
05/19/08 08:20 PM
05/19/08 08:20 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
Wait a minute. I understand not wanting to order two parts just to do a comparison, but you already have both in your possesion. A big block WP is held on by what? four bolts? Yank both of them and do a side by side comparo. I betcha its just a matter of fin count as already mentioned. I'd also be willing to bet that even though there are two different part numbers, the older one has been superceeded by the newer one.
John
