BB Waterpump part numbers #59310
05/18/08 07:48 PM
05/18/08 07:48 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Was looking at water pumps on Partsamerica.com. Checked the price for a 65 Fury III 383 and came up with a part number of 58173 for $29.99
I then checked for the 78 Cordoba 400 I own and it came back with a part number of 58176 with a price of $21.99
Thought parts such as waterpumps for the Big Blocks were all the same?
Where the difference in these 2 parts(if any)?
Re: BB Waterpump part numbers [Re: SPWC] #59311
05/18/08 07:53 PM
05/18/08 07:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The impeller in the pump can have 6 or 8 vanes, 6-vane pumps are generally used with A/C where the pump is driven faster than crank speed; a '65 would most likely use the 8-vane pump.
Re: BB Waterpump part numbers [Re: John_Kunkel] #59312
05/18/08 08:27 PM
05/18/08 08:27 PM
SPWC Offline OP
SPWC  Offline OP
Would it do any harm to use the 78 400 Waterpump on my 65 383? Both vehicles are equipped with AC
Re: BB Waterpump part numbers [Re: SPWC] #59313
05/18/08 08:41 PM
05/18/08 08:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
over 8 bucks ???
Re: BB Waterpump part numbers [Re: JohnRR] #59314
05/18/08 09:12 PM
05/18/08 09:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
over 8 bucks ???
Re: BB Waterpump part numbers [Re: NITROUSN] #59315
05/18/08 10:56 PM
05/18/08 10:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
could the shafts be different lengths causing one be be closer to the rad? Use the one the book calls for and save yourself some possible grief.
Re: BB Waterpump part numbers [Re: stumpy] #59316
05/18/08 11:44 PM
05/18/08 11:44 PM
SPWC Offline OP
SPWC  Offline OP
over 8 bucks ???
The money part isnt an issue. I was told that a BB water pump is a BB Water pump,and that they ALL interchange --PERIOD
Obviously that MAY not be the case.
Re: BB Waterpump part numbers [Re: SPWC] #59317
05/18/08 11:51 PM
05/18/08 11:51 PM
they ALL should interchange.. there may be some oddball exceptions though.
Re: BB Waterpump part numbers [Re: SPWC] #59318
05/19/08 09:47 AM
05/19/08 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
over 8 bucks ???
the difference is the blade count .
i just find it funny that you are over 8 bucks , if it were 30 - 50 bucks , yes , but 8 ????
have them get both and compare them ???? oh , that would be too easy
Re: BB Waterpump part numbers [Re: JohnRR] #59319
05/19/08 11:13 AM
05/19/08 11:13 AM
SPWC Offline OP
SPWC  Offline OP
Im not over 8 bucks. I saw the part numbers awee different so I figured the parts were totally different. So JOHN RR, tell me how I am supposed to compare the 2 parts side by side when noone locally has them in stock and they have to be ordered
When I order them they have to be prepaid!!
Not as easy as you think!!
Re: BB Waterpump part numbers [Re: SPWC] #59320
05/19/08 11:19 AM
05/19/08 11:19 AM
yah it is easy.. order the 8 or 6 blade impeller one call it a day.
getting a waterpump shouldn't be a Jerry Springer show.
Re: BB Waterpump part numbers [Re: SPWC] #59321
05/19/08 12:00 PM
05/19/08 12:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's easier than you're making it out to be .
Re: BB Waterpump part numbers [Re: SPWC] #59322
05/19/08 05:27 PM
05/19/08 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check your pulley diameters, if the crank pulley and WP pulley are close to the same diameter use the 8-vane pump A/C or not. Later A/C cars had smaller WP pulleys to overdrive the fan/pump 140%.
Re: BB Waterpump part numbers [Re: SPWC] #59323
05/19/08 08:20 PM
05/19/08 08:20 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Wait a minute. I understand not wanting to order two parts just to do a comparison, but you already have both in your possesion. A big block WP is held on by what? four bolts? Yank both of them and do a side by side comparo.
I betcha its just a matter of fin count as already mentioned. I'd also be willing to bet that even though there are two different part numbers, the older one has been superceeded by the newer one.
John
Re: BB Waterpump part numbers [Re: SattyNoCar] #59324
05/19/08 08:23 PM
05/19/08 08:23 PM
SPWC Offline OP
SPWC  Offline OP
Ya know I never thought5 of that!!
Re: BB Waterpump part numbers [Re: SPWC] #59325
05/19/08 08:26 PM
05/19/08 08:26 PM
Kirkland, Washington
Pacnorthcuda Offline
and buy an extra gasket while you're at it!
