Rust sealing hard to get to places #592579
01/24/10 11:47 AM
01/24/10 11:47 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I think I have a good design in my head for being able to spray products like POR15 and epoxy primer in those places you can't even see. Just curios what you guys would pay for a kit that would do this. It will definately coat everything and not be as messy as all the other systems I've seen. I'd obviously be able to prove it so let me know what you think and I'll get to work.Thanks-Jake
Re: Rust sealing hard to get to places [Re: jake71] #592580
01/24/10 12:48 PM
01/24/10 12:48 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I think it's agreat idea. Areas like lower inner cowl, quarter to wheel house, windshield frame, door pillars, etc are prone to rust and hard to treat.
I don't know if a paint product would be the best idea, something like light oil or solvent borne wax would be preferred.
Re: Rust sealing hard to get to places [Re: jake71] #592581
01/24/10 12:53 PM
01/24/10 12:53 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I like the idea Jake. I had always expected to use a rustproofing wand ,or something similar, for those hard to reach places.
What would I pay for a tool? I guess it depends on what the tool is. If it's a piece of rubber hose, not much. If it's a quality, American made tool, more.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Rust sealing hard to get to places [Re: DynoDave] #592582
01/24/10 01:19 PM
01/24/10 01:19 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
This will be a quality American made tool far superior to what I've seen as being available on the market today and will be easy to clean also. There will likely be two versions for supplying the 150 psi required for atomization but in general it will be very simple to use and care for. I'll have something put together hopefully by the end of the week with results proven by a test through a piece of clear pvc pipe and square tube if available. I'll post a video of the test when I've got it working properly.
Thanks for the feedback-Jake
Re: Rust sealing hard to get to places [Re: jake71] #592583
01/24/10 07:10 PM
01/24/10 07:10 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Just ordered some specialty tools for machining the parts. Will keep you posted.
Re: Rust sealing hard to get to places [Re: jake71] #592584
01/24/10 08:04 PM
01/24/10 08:04 PM
Jacksonville Florida
elitecustombody Offline
Jake, will your tool accept any type of fluid/coating? What will be the price for one of them?
Re: Rust sealing hard to get to places [Re: elitecustombody] #592585
01/24/10 08:06 PM
01/24/10 08:06 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I used a syringe and vinyl tubing to 'pour' paint/sealer (I used POR15) at the inner 1/4s to outer 1/4's crease. Worked fine
Re: Rust sealing hard to get to places [Re: elitecustombody] #592586
01/24/10 08:54 PM
01/24/10 08:54 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Yes, most will be acceptable as far as viscosity. I have several levels of kits I'm thinking of but they will be customizable if you tell me what you want to spray. The great thing will be that it will be atomized with liquid pressure only (No Air) meaning less "fog" and as I said, the kit will allow multiple rates of application. Let me know what you want to spray and I'll test and tune.
Thank you for the interest-Jake
Re: Rust sealing hard to get to places [Re: Pacnorthcuda] #592587
01/24/10 08:59 PM
01/24/10 08:59 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I do lke the POR15 for it's "traveling" capabilities. This will be for essentially fogging inside of areas not accessable otherwise. It would also work for your application.
Re: Rust sealing hard to get to places [Re: elitecustombody] #592588
01/24/10 09:03 PM
01/24/10 09:03 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Sorry, I forgot to respond to the price question. I don't know for sure but it won't be too bad. I should have an idea by mid next week. I ordered most of what I need for the prototype today so I should have one working soon.-Jake
Re: Rust sealing hard to get to places [Re: jake71] #592589
01/27/10 10:15 PM
01/27/10 10:15 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I'm thinking the tool will be available in "kit" form and will have options ranging from basic "I want to spray fish oil" to full on shop kits with all necessary components to spray most, if not all(excluding rust proofing tars and rubber), currently available converters and encapsulators. The kit, even basic, will include a "snake camera" to allow all users to verify that the job is complete. I'm thinking at this point in design we should have a price range of about $250 to $400. What do you think? There will be a video of how to use it, before and after inside shots.
Re: Rust sealing hard to get to places [Re: jake71] #592590
01/28/10 11:11 AM
01/28/10 11:11 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Jake,
I like the idea, but how would your kit differ from available rust prevention sprayers that use wands and flexible hoses to spray the fluid into nooks and crannys? Here's an example of what I'm talking about: http://www.eastwood.com/rustproofing-and-undercoating-system.html
Looking forward to your kit and the video.
Re: Rust sealing hard to get to places [Re: mrob] #592591
01/28/10 12:30 PM
01/28/10 12:30 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Jake,
This system will be easier to get the entire frame coated and it will center itself in the rail. The nozzle I'm using will be better capable of a spray gun like atomization of the coating therefore reducing waste and mess. I'm pretty sure I'll be including a camera with all of the kits as I've been able to source them pretty cheap. With the camera, you'll be able to inspect before you start so as to be able to make a decision on what product will best suit your needs. Also, when you're done you'll be able to verify complete coverage.
I've got most of what I need to build the prototype so hopefully I'll have the rest before the weekend so I can start building it.
Thanks for the interest and keep feedback coming. It's hard to think of everything so I'd like to build this based on consumer experience.
Re: Rust sealing hard to get to places [Re: jake71] #592592
02/10/10 05:42 PM
02/10/10 05:42 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: Rust sealing hard to get to places [Re: Ply72rr] #592593
02/18/10 09:21 PM
02/18/10 09:21 PM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
So hows it goin jake?
Re: Rust sealing hard to get to places [Re: Birdturd] #592594
03/10/10 07:34 PM
03/10/10 07:34 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I'm sorry, I've been busy with...
Anyway, I do have a prototype in action and it does spay like I had hoped-almost. I have to work on the nozzle design a bit but it should be pretty awesome when it's done. Hang with me while I get some of my other ducks in a row. Business first!
I'll try to get some pics and or video of it at least showing the spray pattern soon.
Thanks for the interest-Jake
Re: Rust sealing hard to get to places [Re: jake71] #592595
03/14/10 01:04 PM
03/14/10 01:04 PM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
Jake has some great ideas, and I am not taking away from that...
I used a spray in product that has a rubber flexible hose and sprays out in four directions. You slide it in and then spray as you pull it back out slowly. I did this in my frame rails and any other hard to reach places. It worked great. I have only had the car on the road a year, so time well tell but so far so good. My friend who is a bodyman recommended it. I will find out the name and type of product used. I dont have the info here. The body man friend is on this site as BAN-ONE
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
