Re: 4 speeds and 1/4 times.... #591594
01/26/10 04:53 PM
01/26/10 04:53 PM
IL
acme383 Offline
acme383  Offline
IL
9.20@144mph 3400Lbs, on 10.5w's
"Beating the competition with a stick is just automatic!"
Re: 4 speeds and 1/4 times.... [Re: acme383] #591595
01/26/10 06:00 PM
01/26/10 06:00 PM
Idaho
Runner Offline
Runner  Offline
Idaho
hey big squeeze, when you say stock clutch what exaclty do you mean? i assume your using a stock replacement clutch? whos clutch are you using? preasure plate? what rearend gears? and how are you launching the car?
Re: 4 speeds and 1/4 times.... [Re: Lawn Monkey] #591596
01/26/10 06:13 PM
01/26/10 06:13 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ed Cook's kid James' FAST A12 RR.
Car weighs about 3,850 w/driver. 100% FAST legal 493" w/stock sixpack. Worn out CF dual friction clutch with stock shifter. No suspension tricks. Liberty geared 833. On the G60-15 bias ply redline tires. The kid can drive the car well.
11.12 @126.
Re: 4 speeds and 1/4 times.... [Re: HPMike] #591597
01/26/10 07:50 PM
01/26/10 07:50 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
My best ever with the 383 was a 12.56 at somewhere around 107. This is in a 70 RR, at the time it was with the 3.73 741 case rear and a 23 spline A833. I was running slicks and collector extensions on the headers, otherwise just as driven on the street. The clutch was an old Hays Pro Stock that kept your left leg in shape. Guessing with me in it the car is about 4000 lbf. Eventually blew up the rear but what went was the left (stock) axle shaft, broke clean off, twisted the right shaft, broke teeth off the spider gears inside the Sure-Grip, and you could see where the ring gear had been hitting the housing. The ring and pinion were fine, sold them to someone here on Moparts and as far as I know they are dong fine.
Now the car has a 452 built by DRAM. The rear is a 4.3 Strange 60 with a Tru Trac. Still the original rear springs, with clamps on the forward sections. Same tranny. Clutch has a Mcleod 800 disc, which has organic facings on the pressure plate side and kevlar puck like thingies on the flywheel side. Pressure plate is a Mcleod that was reworked by 4speedsavoy's clutch guy. At the time the car had the 383 (blew it up not long after installing the new clutch and scattershield) so hopefully it will still work with slicks. Have not had a chance to take it to the track yet. Have heard that the track is open the 5th February so hopefully will get to test it that night.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: 4 speeds and 1/4 times.... [Re: Runner] #591598
01/26/10 08:12 PM
01/26/10 08:12 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
My combo is fairly close to the OP's.
Very close to stock 40k original mile 1966 440(untouched stock bore, pistons, bearings, etc.) Orig. 516 heads with larger exhaust valves, .509 MP cam, Hooker 1 7/8" headers, 3" exhaust to Flowmasters.
Torker II single plane intake with Holley 750 DP carb.
Stock MP HP clutch setup, stock Hemi 4 speed, Super Stock springs, snubber, 4.10 rear gear with 28x12.50 ET Street tires.
Heavy all steel street car except glass T/A hood.
I've only had it to the track a few times (notice no cage and window half down in pic ) but I've owned, driven, and street raced this car for 30 years.
Best ET was 11.83 with a soft launch to keep from breaking the 8 3/4 rear(again)
Re: 4 speeds and 1/4 times.... [Re: gearjammerdart] #591599
01/26/10 08:45 PM
01/26/10 08:45 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Now that would be fun to drive.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: 4 speeds and 1/4 times.... [Re: JD Dart] #591600
01/26/10 09:48 PM
01/26/10 09:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
A 4-speed can be just as quick as an auto if you can drive it. I see alot of stick cars with not so good drivers. The auto is much easier to drive and not as hard on the drivetrain. I used to bracket race a 340 four speed Dart and I loved driving it. Ran 11.94 @ 112 best. It was fun banging gears and to me you need to make your stick car sound like an auto shifting if you know how to drive it. But my auto in my 63 is much easier on the drivetrain. I cant imagine how good the drivetrain needs to be on 10 second and faster stick cars. Ron
Re: 4 speeds and 1/4 times.... [Re: Runner] #591601
01/26/10 11:29 PM
01/26/10 11:29 PM
When I say stock clutch, I mean rag disc.......It's got a Mcleod pressure plate.......I recently bought a #98503 Ram Power Grip Performance disc and plate that I'll be installing next week......I'll use that to find the next weakest link......
Car's got 4.10's with a 27X10.5 Hoosier QT/Pro (I figure using that tire on the typical Friday night TNT at Tulsa is like racing on bias ply poly's at a track that's prepped as good as most of the FAST races.... ).....If I leave very hard, it just runs through the clutch, so I rev to about 3K, get the peddle all the way out and then put the hammer down and start rowing gears......Best 60' is a 1.66, so it's got a lot of room for improvement........
It's also got a Passon Performance aluminum crash box with synchro'd 1st for easy street driving The trans shifts like butter...... I don't know what I'm shifting at.......Car doesn't have a tach in it .......It's got a 7K chip in the 6AL and I've never hit it.......so I'm guessing that I'm shifting around 6,400-6,600........
I'm dying for the track to open so I can hopefully get it into the 10.40 to 10.50 range.....and hopefully get a little more trap speed out of it with some tuning.....
The 10.86 run was at 3,200 DA.......I'd really like to run it at E-town when the FAST guys are there in mine shaft air......
Wayne
Re: 4 speeds and 1/4 times.... #591602
01/26/10 11:33 PM
01/26/10 11:33 PM
Idaho
Runner Offline
Runner  Offline
Idaho
thanks big squeeze, thats a neat car you have!
Re: 4 speeds and 1/4 times.... [Re: Lawn Monkey] #591603
01/27/10 10:19 AM
01/27/10 10:19 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I know auto is faster but I like gears,,,,,
All things being equall a stick is quicker and faster than a slush box. More fun too. Also more headache. If a gear box is in your future do not skimp on a clutch. That makes or breaks the deal.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 4 speeds and 1/4 times.... [Re: Lawn Monkey] #591604
01/27/10 02:45 PM
01/27/10 02:45 PM
The State of Hockey
2qik4u Offline
2qik4u  Offline
The State of Hockey
12.43 @ 110 mph with an A-833.
Re: 4 speeds and 1/4 times.... [Re: toddd] #591605
01/27/10 09:28 PM
01/27/10 09:28 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
My best is a 10.30 @131.11.
I was using 1-2 Pro shifted and 3-4 face plated Hemi 4 speed.
It's an absolute blast to drive.
What is the face plating process and how much does it usually cost?
Re: 4 speeds and 1/4 times.... [Re: Blakcharger440] #591606
01/28/10 11:38 AM
01/28/10 11:38 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Never had a Mopar w/o a stick!
Re: 4 speeds and 1/4 times.... [Re: Kudakidd] #591607
01/29/10 12:19 AM
01/29/10 12:19 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
9.92@135 1.32 60ft. Jerico DR-4. Have`nt tried to see how fast it will go yet.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 4 speeds and 1/4 times.... [Re: 6bblFLASH] #591608
01/29/10 03:53 PM
01/29/10 03:53 PM
Toronto
mshred Offline
mshred  Offline
Toronto
im assuming that most of you guys are running 18 splines?
Re: 4 speeds and 1/4 times.... [Re: mshred] #591609
01/29/10 04:19 PM
01/29/10 04:19 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
23 spline here. If something "gives" and it's not overly powerfull / heavy,....it SHOULD live.
My tires do all the slipping at the line, to keep the car in it's powerband and keep the shock off the hard parts. Just a couple revolutions of the tire and then we are hooked.
Re: 4 speeds and 1/4 times.... [Re: mshred] #591610
01/29/10 04:55 PM
01/29/10 04:55 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Nope. 23 spline here also
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 4 speeds and 1/4 times.... [Re: 68LAR] #591611
01/29/10 09:24 PM
01/29/10 09:24 PM
Toronto
mshred Offline
mshred  Offline
Toronto
sweet deal! i guess with a good clutch even a 23 spline can take some serious abuse...sweeeet!
