73' Satellite trim question #591389
01/23/10 04:31 AM
01/23/10 04:31 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
Is there a special name for the piece of trim attached to the rear bumper? It's the long piece that runs the length of the bumper located between the bumper and the trunk... I'm searching everywhere online for a replacement piece and I'm having trouble finding it.
Re: 73' Satellite trim question [Re: 2ndopp] #591390
01/23/10 05:14 AM
01/23/10 05:14 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Yep...it's a bumper filler and it's not repopped by anyone. Good luck finding one. Your best bet is to find a decent original. Sorry.
Re: 73' Satellite trim question [Re: Hotwheelsjr] #591391
01/23/10 02:58 PM
01/23/10 02:58 PM
England
moonman Offline
moonman  Offline
England
There's one listed at http://www.tonysparts.com/BrowseResults.asp cheers Doug
Re: 73' Satellite trim question [Re: moonman] #591392
01/23/10 05:51 PM
01/23/10 05:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep, usually called a bumper filler strip and finding a good one is near impossible. Junk design to begin with and crappy material. Mine was also shot so I took it off and have just been living with the extra gap.
Re: 73' Satellite trim question [Re: DaytonaTurbo] #591393
01/23/10 06:02 PM
01/23/10 06:02 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
Mine is somewhere between being decrepit and just okay... I'm leaving it until it falls out.
The Blue Goose
My instagram: Bossride
Re: 73' Satellite trim question [Re: BossRide] #591394
01/23/10 08:44 PM
01/23/10 08:44 PM
Central TX
roe Offline
roe  Offline
Central TX
seems like it would be a pretty simple piece to repop, and I bet the demand would be there. I wonder why no one has stepped up to repop those
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 73' Satellite trim question [Re: roe] #591395
01/24/10 08:10 AM
01/24/10 08:10 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Actually There was a Guy that had several made. They looked pretty good in the pics. I saw them on here or ebay when I was redoing my '73 RR about 18 months ago. He had them for a while. Mine was very good shape so I did not buy one.
Re: 73' Satellite trim question [Re: roe] #591396
01/24/10 04:19 PM
01/24/10 04:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The center filler has a step in it and also has an internal metal "c" channel that runs the length of the piece...The C channel fastens to the top edge of the bumper and holds it in place...That piece would be a pricey part to manufacture...So when you're on the boneyard hunt not only does it first need to be straight but the metal c channel needs to be intact or there's no way to keep it on the bumper... ...I gave up on finding a suitable piece that was'nt made of gold and made up my own...
Re: 73' Satellite trim question [Re: screamindriver] #591397
01/24/10 06:05 PM
01/24/10 06:05 PM
Manitoba, Canada
Manitoba, Canada
Heck, even if someone made one where the middle section was held onto the bumper with double sided adhesive tape I'd be happy!
Re: 73' Satellite trim question [Re: sbhpcb] #591398
01/24/10 07:33 PM
01/24/10 07:33 PM
Ma, USA North of Boston
74SatSundance Offline
Yes, somebody out of Ohio I think.
They even had some repops on ebay about a year ago.
the guy had a company do a small run. When I found them on ebay, there were only bleemed ones remaining.
I kick myself for not buying one, but I had no idea what the quality was. I think they wanted $150 bucks for them too.
Good luck finding them. Just about everyone with a 73-74 satellite 2 door and R.R. needs one.
Mines is weathered badly and no longer straight but it is better than nothing.
I even put it on my Christmas list one year for gags and everyone in the family was looking for one. I almost got one from a 72 from someone because thats all they could find.
Very hard to repop correctly. The guy went through several runs before he got one he liked and had racked up the bucks trying to do it, then gave up I think cause he didn't like the final outcome completely.
Some of my detatils here may not be correct as I am doing this all from memory.
The ones on Tony's site are probaly the outer ends, cause he says fillers "plural".
He ALSO lists one for a front. I wonder what that could be, as there are no rubber fillers on the front.
Re: 73' Satellite trim question [Re: 74SatSundance] #591399
01/24/10 07:46 PM
01/24/10 07:46 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
maybe someone could just make shorter mounting brackets, and tuck the bumper up close to the body
Re: 73' Satellite trim question [Re: James74] #591400
01/25/10 12:06 AM
01/25/10 12:06 AM
Harrisburg, Pa.
Harrisburg, Pa.
I was thinking about that also and did the mock up...But when you move the bumper in the side width looks way off compared to rest of the gaps... For the rear bumper to look right going that route you'd need to section the bumper in the center and lose a few inches off the width and pull the ends in closer...
Re: 73' Satellite trim question [Re: screamindriver] #591401
01/25/10 12:11 AM
01/25/10 12:11 AM
Manitoba, Canada
Manitoba, Canada
Also, when you move the bumper in, you find there's a gap on top of and below the bumper, like the bumper's not tall enough for the space it's supposed to fill. They designed that bumper with that damned filler strip in mind and there's no way to get around that very easily, so I just live with the gap. Wish I would have heard about those repops back then, I would have been all over that.
Re: 73' Satellite trim question [Re: DaytonaTurbo] #591402
01/26/10 01:19 AM
01/26/10 01:19 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
Re: 73' Satellite trim question [Re: 2ndopp] #591403
01/26/10 10:56 AM
01/26/10 10:56 AM
Wilmington NC
Blue70 Offline
Blue70  Offline
Wilmington NC
Mine is there but a little wavy..
I might have to give that a try
Re: 73' Satellite trim question [Re: Blue70] #591404
02/12/10 02:37 AM
02/12/10 02:37 AM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
Found my old one in storage. It's VERY wavy... I got weights on it trying to straighten it out right now. I'll paint it up and maybe silicone it to the bumper?
Re: 73' Satellite trim question [Re: 2ndopp] #591405
02/12/10 06:10 AM
02/12/10 06:10 AM
South Carolina
Hawg_Man Offline
Hawg_Man  Offline
South Carolina
I did find some instructions for making your own:
http://www.muskie-lures.com/73roadrunner/73_road_runner_rear_bumper_center_trim.htm
I made one very similar........got 1/4" x 1 1/2" x 8 Ft PVC from Lowes and painted it with Fusion paint....looks pretty good.
Re: 73' Satellite trim question [Re: 2ndopp] #591406
02/12/10 08:13 AM
02/12/10 08:13 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
dang...we had a perfect original one that we listed on Ebay years ago that didn't sell, we ended up tossing it. Sorry guys.
Re: 73' Satellite trim question [Re: 74SatSundance] #591407
02/12/10 10:52 PM
02/12/10 10:52 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
the bumper filler on the front is aluminum, one piece under each headlight.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
