Window net installation pictures #590806
01/22/10 02:41 PM
01/22/10 02:41 PM
NC
Badfish67 Offline OP
NC
Anyone have any pictures or can take a picture of their window net installation? I just got a RJS #999 net and the angle of the net is not the same angle as my cage so I would like to see how you guys mounted yours.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: Window net installation pictures [Re: Badfish67] #590807
01/22/10 04:20 PM
01/22/10 04:20 PM
heres mine, a little tab locks it in on the side bar with a lower rod.
Re: Window net installation pictures [Re: Badfish67] #590808
01/22/10 04:45 PM
01/22/10 04:45 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Mine
Re: Window net installation pictures [Re: B1KILLER] #590809
01/22/10 04:47 PM
01/22/10 04:47 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
2
Re: Window net installation pictures [Re: Badfish67] #590810
01/22/10 06:14 PM
01/22/10 06:14 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I bent the bottom rod just past where it slips thru the front of the net at a 30 degree angle or so til it intersected with the door bar, and then bent it straight again parallel to the door bar so that the rod would line up and slide into the weld on bushing on the door bar. IIRC I had to buy a longer rod to do this, but they are available at any Home Depot or similar center. For the back of the bottom rod I welded the bushing to the main bar that goes across the main hoop.
Re: Window net installation pictures [Re: Sixpak] #590811
01/22/10 09:03 PM
01/22/10 09:03 PM
Saskatchewan, Canada
barracudabob Offline
Does it matter if they're on the inside or the outside of the cage? Thanks, Bob
Re: Window net installation pictures [Re: barracudabob] #590812
01/22/10 09:51 PM
01/22/10 09:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
They must be mounted inside the cage.
I just had to relocate mine cuz I over looked that little tid bit
Post deleted by Defbob [Re: Badfish67] #590813
01/22/10 10:00 PM
01/22/10 10:00 PM
Post deleted by Defbob #590814
01/22/10 10:58 PM
01/22/10 10:58 PM
Re: Window net installation pictures #590815
01/22/10 11:53 PM
01/22/10 11:53 PM
NC
NC
What company makes a custom size window net?
Re: Window net installation pictures [Re: Badfish67] #590816
01/23/10 02:58 AM
01/23/10 02:58 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Stroud will make you a custom net, but I bet their angled net will fit fine. I went through this exact same thing when building my car. I looked at the measurements they have and ordered one. It was almost a perfect match to my cage/door bar. www.stroudsafety.com
Hope this helps.Beep
Re: Window net installation pictures [Re: Badfish67] #590817
01/23/10 09:39 AM
01/23/10 09:39 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
RJS will make a custom net for $40. I thought a long time about mine. I used an availible 24"x24" net so I could mount the lower rod in a fixed position. I didn't need a cable at the front. My buddys GTX has a neat system also. The rods are vertical and have a bend in them to follow the contour of the inside of the cage. The front rod can pivot rearward at the bottom. The rear rod is in a fixed position.
Doug
