Window net installation pictures
#590806
01/22/10 02:41 PM
01/22/10 02:41 PM
Posts: 84 NC
Badfish67
NC
Anyone have any pictures or can take a picture of their window net installation? I just got a RJS #999 net and the angle of the net is not the same angle as my cage so I would like to see how you guys mounted yours. Thanks
1967 Barracuda
360ci/727
9.723ET @139.44mph
Re: Window net installation pictures
[Re: Badfish67]
#590807
01/22/10 04:20 PM
01/22/10 04:20 PM
heres mine, a little tab locks it in on the side bar with a lower rod.
[Re: barracudabob]
#590812
01/22/10 09:51 PM
01/22/10 09:51 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
They must be mounted inside the cage.
I just had to relocate mine cuz I over looked that little tid bit
Post deleted by Defbob
[Re: Badfish67]
#590813
01/22/10 10:00 PM
01/22/10 10:00 PM
#590814
01/22/10 10:58 PM
01/22/10 10:58 PM
#590815
01/22/10 11:53 PM
01/22/10 11:53 PM
Posts: 84 NC
Badfish67
NC
What company makes a custom size window net?
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Badfish67]
#590816
01/23/10 02:58 AM
01/23/10 02:58 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Stroud will make you a custom net, but I bet their angled net will fit fine. I went through this exact same thing when building my car. I looked at the measurements they have and ordered one. It was almost a perfect match to my cage/door bar. www.stroudsafety.com Hope this helps.Beep
[Re: Badfish67]
#590817
01/23/10 09:39 AM
01/23/10 09:39 AM
Posts: 9,824 MI, usa
dvw
MI, usa
RJS will make a custom net for $40. I thought a long time about mine. I used an availible 24"x24" net so I could mount the lower rod in a fixed position. I didn't need a cable at the front. My buddys GTX has a neat system also. The rods are vertical and have a bend in them to follow the contour of the inside of the cage. The front rod can pivot rearward at the bottom. The rear rod is in a fixed position. Doug
