Aftermarket/Non-Factory Ebody Road Lamps
#590600
01/22/10 12:24 AM
01/22/10 12:24 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am looking to see what aftermarket or non-factory application road lamps have been used on ebodies? I'm looking for a similar look, but not the price tag. Preferably something with a removable bulb since I would be retrofitting HIDs into them. Also, what diameter are they? Thanks!
Re: Aftermarket/Non-Factory Ebody Road Lamps
[Re: RylisPro]
#590603
01/22/10 07:32 AM
01/22/10 07:32 AM
Posts: 158 PA
dodgeman316
PA
RylisPro, I don't mean to highjack the thread but what are your plans for turn signal lights on that Cuda in the picture you posted or is that a race-only car?
1969 Super Bee
[Re: autoxcuda]
#590604
01/22/10 10:12 AM
01/22/10 10:12 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks!
67? Mustang fog lamps are nearly identical except for the "tri bar" in the center. Rest of the chrome bezel casting is nearly the same. They take the same bulb.
I know someone that bought a set of mustang fog lamps and cut the tri bar out and re-assemblied them. Would really need to stare at them from 5 feet away to tell if someone clued you in. He had some homemade fog lamp brackets too.
I thought there was something mustang related that people used, but wasn't sure. Thanks, I'll look into those.
[Re: autoxcuda]
#590605
01/22/10 10:14 AM
01/22/10 10:14 AM
Posts: 1,286 Ft. Lauderdale, FL
solarguy
Ft. Lauderdale, FL
[quote 67? Mustang fog lamps are nearly identical except for the "tri bar" in the center. Rest of the chrome bezel casting is nearly the same. They take the same bulb. I know someone that bought a set of mustang fog lamps and cut the tri bar out and re-assemblied them. Would really need to stare at them from 5 feet away to tell if someone clued you in. He had some homemade fog lamp brackets too.
I used ones from a mustang catalog and they have the bezels without the tri bar. Real hard to tell any differnce between mine and the repop ones for mopar. cost was around 125 for the pair
http://www.ponypartsplus.com/
[Re: dodgeman316]
#590607
01/22/10 10:49 AM
01/22/10 10:49 AM
Posts: 2,432 NorCal
RylisPro
NorCal
what are your plans for turn signal lights ?
I have the side ones & I can still use my left arm
