Aftermarket/Non-Factory Ebody Road Lamps #590600
01/22/10 12:24 AM
01/22/10 12:24 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am looking to see what aftermarket or non-factory application road lamps have been used on ebodies? I'm looking for a similar look, but not the price tag. Preferably something with a removable bulb since I would be retrofitting HIDs into them.
Also, what diameter are they?
Thanks!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: GoodysGotaCuda] #590601
01/22/10 02:12 AM
01/22/10 02:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks!
67? Mustang fog lamps are nearly identical except for the "tri bar" in the center. Rest of the chrome bezel casting is nearly the same. They take the same bulb.
I know someone that bought a set of mustang fog lamps and cut the tri bar out and re-assemblied them. Would really need to stare at them from 5 feet away to tell if someone clued you in. He had some homemade fog lamp brackets too.
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: GoodysGotaCuda] #590602
01/22/10 02:12 AM
01/22/10 02:12 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I put these Hella Optilux 1100 on for the time being
http://www.amazon.com/Hella-H71010291-Optilux-1100-Clear/dp/B0002MA3NU
and put in some high discharge led H3 bulbs
everything cost 40 bucks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: RylisPro] #590603
01/22/10 07:32 AM
01/22/10 07:32 AM
PA
dodgeman316 Offline
dodgeman316  Offline
PA
RylisPro, I don't mean to highjack the thread but what are your plans for turn signal lights on that Cuda in the picture you posted or is that a race-only car?
1969 Super Bee
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: autoxcuda] #590604
01/22/10 10:12 AM
01/22/10 10:12 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks!
I thought there was something mustang related that people used, but wasn't sure. Thanks, I'll look into those.
2020 RAM 1500
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: autoxcuda] #590605
01/22/10 10:14 AM
01/22/10 10:14 AM
Ft. Lauderdale, FL
solarguy Online content
solarguy  Online Content
Ft. Lauderdale, FL
[quote
I used ones from a mustang catalog and they have the bezels without the tri bar. Real hard to tell any differnce between mine and the repop ones for mopar. cost was around 125 for the pair
http://www.ponypartsplus.com/
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: dodgeman316] #590606
01/22/10 10:15 AM
01/22/10 10:15 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The local mustang supplier here even sells the chrome bezels without the center divider making the whole deal real easy and cheap...Only difference on the housings are obvoiusly the part number and a set of rivets{around the housing} holding the inner support ring in place....Here's just one supplier's page...There's a bunch out there !!! link
Re: Aftermarket/Non-Factory Ebody Road Lamps [Re: dodgeman316] #590607
01/22/10 10:49 AM
01/22/10 10:49 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
what are your plans for turn signal lights ?
I have the side ones & I can still use my left arm
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
