Re: Wiper Motor Rebuild
[Re: srunge55]
#590500
01/21/10 11:42 PM
01/21/10 11:42 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
an internal cam on shaft or gear. Thats the cut off power function.
[Re: NachoRT74]
#590501
01/22/10 12:14 AM
01/22/10 12:14 AM
RapidRobert
Nacho is that the circuit that stays hot until it parks then the cam "opens" it there
[Re: JulesdaWiperman]
#590503
01/22/10 01:09 AM
01/22/10 01:09 AM
MoreParts
Steve, that contact is NOT set correctly. The contact must be closed with a slight tension on the terminal. Bend the tang slowly over the terminal and make sure it passes the terminal by 1/4 inch on the opposite side. Then slowly bring it back over the terminal so that it rests on it with tension. Jules
Jules was a big help to me with this info.
Also, when reassembling make sure you put the tab in the correct grove. Mine was installed incorrectly and I kept having to rebend until I learned the correct placement. If your part number is readable you may be able to get some help with the correct installation.
