Wiper Motor Rebuild #590499
01/21/10 10:51 PM
01/21/10 10:51 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I am putting my 69 3 speed motor back together. Can someone tell me if the contacts on the back of the transmission cover look to be set correctly? What causes the contacts to close. I can't quite figure it out. Please see picture.
Thanks,
Steve
Re: Wiper Motor Rebuild [Re: srunge55] #590500
01/21/10 11:42 PM
01/21/10 11:42 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
an internal cam on shaft or gear. Thats the cut off power function.
Re: Wiper Motor Rebuild [Re: NachoRT74] #590501
01/22/10 12:14 AM
01/22/10 12:14 AM
Nacho is that the circuit that stays hot until it parks then the cam "opens" it there
Re: Wiper Motor Rebuild [Re: RapidRobert] #590502
01/22/10 12:21 AM
01/22/10 12:21 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Steve,
that contact is NOT set correctly.
The contact must be closed with a slight tension on the terminal.
Bend the tang slowly over the terminal and make sure it passes the terminal by 1/4 inch on the opposite side.
Then slowly bring it back over the terminal so that it rests on it with tension.
Jules
Re: Wiper Motor Rebuild [Re: JulesdaWiperman] #590503
01/22/10 01:09 AM
01/22/10 01:09 AM
MoreParts Offline
MoreParts  Offline
Steve,
Jules
Jules was a big help to me with this info.
Also, when reassembling make sure you put the tab in the correct grove. Mine was installed incorrectly and I kept having to rebend until I learned the correct placement. If your part number is readable you may be able to get some help with the correct installation.
Re: Wiper Motor Rebuild [Re: MoreParts] #590504
01/22/10 01:20 AM
01/22/10 01:20 AM
super gas
super gas
You can call me if you need help.
450-656-5438
Re: Wiper Motor Rebuild [Re: JulesdaWiperman] #590505
01/22/10 01:48 AM
01/22/10 01:48 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Thanks a bunch for the help. I think I understood your instructions correctly. Does this look right now?
Re: Wiper Motor Rebuild [Re: srunge55] #590506
01/22/10 02:21 AM
01/22/10 02:21 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
NOS 70-71 switch plate.
Re: Wiper Motor Rebuild [Re: Snoopy] #590507
01/22/10 04:36 AM
01/22/10 04:36 AM
Snoopy Offline
Snoopy  Offline
Close-up of switch contacts.
Re: Wiper Motor Rebuild [Re: Snoopy] #590508
01/22/10 08:41 AM
01/22/10 08:41 AM
super gas
super gas
No. That is not good.
Snoopy's picture shows it best.
If you want to improve on the nos configuration, take the tip where the contact is and bend
it slightly so that the full surface of the point touches the terminal.
There is a smaller chance of bad contact this way.
Thanks Snoopy.
Jules
