Rear drum too big for wheel #590457
01/21/10 09:53 PM
01/21/10 09:53 PM
Clarkston, MI
2
2RTSE Offline OP
2RTSE  Offline OP
Clarkston, MI
I have a 70 RR that I am building. I just bought 15X10 Weld wheels and when I tried to install, the diameter of drum would not allow the wheel to slide on. The drums are 11 inch and interfere by about 1/2 inch diameter. Has anyone run into a similar problem? I have a 10 inch front drum from a previous car and it drops right in. I suppose I could try to find a 10 inch set-up but that won't be easy and I thought I'd ask here first.
Thanks,
Steve
Re: Rear drum too big for wheel [Re: 2RTSE] #590458
01/21/10 10:02 PM
01/21/10 10:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
An early 11" drum without the cooling fins would probably fit...
Re: Rear drum too big for wheel [Re: 1_WILD_RT] #590459
01/22/10 08:10 AM
01/22/10 08:10 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have 15x10 Weld Pro Stars on my 65.It has a 69 runner rear with 11 in brakes.No problems.Rocky
Chrysler Firepower
Re: Rear drum too big for wheel [Re: therocks] #590460
01/22/10 10:44 AM
01/22/10 10:44 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
I converted to 11 x 2 brakes on my Dart but running 15 x 7 Weld Pro Stars. No problems. Here is a pic of the drum.
Re: Rear drum too big for wheel [Re: 1_WILD_RT] #590461
01/22/10 11:23 AM
01/22/10 11:23 AM
Clarkston, MI
2
2RTSE Offline OP
2RTSE  Offline OP
Clarkston, MI
According to the NAPA website, 11 inch front drums are 3/4 in. smaller O.D. than rears. I am going to give that a try.
Thank You
Re: Rear drum too big for wheel [Re: 2RTSE] #590462
01/22/10 01:06 PM
01/22/10 01:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Front to rear likely won't interchange do to the offset built int the mounting surface of the drum... Not saying it won't but you need to check closely..
