E-brake help needed
#58968
05/17/08 01:57 PM
05/17/08 01:57 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
Hi all, last year (or maybe it was two years ago) I got my emergency brake mechanism for my 1970 Barracuda re-built by a fella who posts here named Jules Daddio. I'm not griping about Jules as he did a phenominal job on the mechanism. It looks like brand new. I highly recommend him for this type of work. He also does wiper motors, heater boxes,etc.
Anyway, my problem is this: When I press down on the e-brake it acts as if it isn't hooked up. I got it adjusted all the way to where I am almost out of adjustment and I still can't feel it pulling on the brakes shoes. I checked the placement of the brake cables against my brother's 1970 Challenger and they are correct. I know I must be doing something wrong but after looking at the car 4 times over the last two summers I am stumped. Any help would be appreciated.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
Re: E-brake help needed
[Re: stumpy]
#58970
05/19/08 01:42 PM
05/19/08 01:42 PM
LimelightCuda
The Garden State
Thanks for the suggestion Stumpy. At first I thought could it really be that simple? I checked and adjusted the rear brakes yesterday and no change.
Then I tried to press down on the e-brake pedal while holding the cable underneath the car. The pedal went to the floor while the cable did not move at all. I guess I must have somehow hooked it up wrong. The next nice day I'll try to figure out the proper way to connect the cable to the e-brake assembly. Thanks anyway.
Phil
[Re: Pacnorthcuda]
#58972
05/23/08 01:09 AM
05/23/08 01:09 AM
LimelightCuda
The Garden State
Yes, I adjusted the nut on the part where it goes from one cable to two cables. I did this when I first installed the e-brake assembly. The adjustment went WAY past where it was originally and the brake still never gets tight. I'm going to try again this weekend. Thanks for the help.
Phil
[Re: 79powerwagon]
#58974
05/26/08 02:06 PM
05/26/08 02:06 PM
LimelightCuda
The Garden State
Thanks for the help guys. I worked on the car for 2 hours yesterday and I finally found the problem. After trying all the suggestions here which included taking off one of the rear tires and drum I decided to look at the shop manual. I noticed in the drawing of the e-brake assembly there is a clamp that holds the cable in place. On the car the clamp was missing. I thought about it for a while and then I remembered I did not send the clamp to Jules Daddio. Finally, and very luckily, I found the clamp and clamped down the emergency brake cable, then adjusted it and it finally works again. I guess I had a brain fart when I installed it. Thanks again.
Phil
