Adjstable pinion snubber ? #589726
01/21/10 08:13 AM
01/21/10 08:13 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
(E) body adjustable snubber clearance? for race and cruising, if there is a differance, this not a drag car, just hopeing for a little help on the track with street tires.
Re: Adjstable pinion snubber ? [Re: Lew] #589727
01/21/10 08:44 AM
01/21/10 08:44 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I set mine an inch away from the floorboard. The problem is you will spin easier with the snubber. You need sticky tires.
Re: Adjstable pinion snubber ? [Re: ireland383] #589728
01/21/10 09:18 AM
01/21/10 09:18 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
But with out the snubber you have a better chance of breaking things.
logan426
Re: Adjstable pinion snubber ? [Re: Lew] #589729
01/21/10 10:08 AM
01/21/10 10:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Ideally, it would be cool to rig a solenoid of some sort, to de-activate and lower it as soon as you're done racing for the day, so you can get the suspension travel back. Ah, that's too much like work.
Re: Adjstable pinion snubber ? [Re: buildanother] #589730
01/21/10 12:11 PM
01/21/10 12:11 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
I adjust mine to within a quarter inch of the floor when on the track and as far away from the floor as possible on the road.
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: Adjstable pinion snubber ? [Re: Roppa440] #589731
01/21/10 12:21 PM
01/21/10 12:21 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
The problem with MP's POS is that you can't lower it enough for street use. And if you are going to use one, weld a gusset between the base and the vertical tower with all the useless holes. They bend real easily. Thanks MP!
Re: Adjstable pinion snubber ? [Re: Kudakidd] #589732
01/21/10 12:41 PM
01/21/10 12:41 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
The screw in type only offers slightly more clearance. If you're running stock ride height, you pretty much have to use a stock snubber.
Bottoming out a snubber on the street will really bruise your kidneys.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Adjstable pinion snubber ? [Re: Lew] #589733
01/21/10 12:49 PM
01/21/10 12:49 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
The pinion Snubbers work great at the 1 inch adjustment. Just make sure your leaf springs are not warn out or weak. Sometimes you need to upgrade to the SS springs or just replace your originals. Soft tires or slicks are a must on the track.
Joe Sr.
Re: Adjstable pinion snubber ? [Re: joewhite440] #589734
01/21/10 04:57 PM
01/21/10 04:57 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
I cut my MP snubber so that it gave me the correct adjustability I needed for a stock ride height.
Re: Adjstable pinion snubber ? [Re: MLR426] #589735
01/21/10 05:36 PM
01/21/10 05:36 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
logan426
But WITH the correct rear springs .. you do NOT need the PS.
A PS is nothing but a band-aid for a problem that can be solved with PROPER EQUIPMENT.
Re: Adjstable pinion snubber ? [Re: dOc !] #589736
01/21/10 06:04 PM
01/21/10 06:04 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I've sold quite a few of these Sox and Martin style dana 60 pinion snubbers without any complaints. They are manufactured right here in the U.S.A. and have the gusset that I think Mark was talking about. I've never recieved any feedback on street or strip use so I can't comment on how good or bad it functions. I usually say no news is good news. Has anybody used this Sox and Martin style snubber and care to comment on it? Good or bad.
Re: Adjstable pinion snubber ? [Re: badblack68] #589737
01/21/10 06:08 PM
01/21/10 06:08 PM
Yep, PITA on the street.
Not worth the $$ or the hassle IMO.
I installed one on a '71 Cuda a few years back and it was worthless.
Re: Adjstable pinion snubber ? [Re: dOc !] #589738
01/21/10 06:15 PM
01/21/10 06:15 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I don't use one. When I did it made matters worse. If you think about how the rear suspension works, the snubber won't touch the floor board at launch anyway. The only reason the Ma Mopar put them on was to compensate for over loads in the trunk of a street car. It kept the back end from bottoming out. When you launch a Mopar, because of the short front spring segment,(which acts like a traction bar), the back of the car raises. Unlike a Ford or Chevy, that squat. If the back of the car raises, how is the pinion snubber going to come in contact with the floor board?
I run SS springs. My back end raises almost 3" at launch. With OE HD springs the same thing happens, but not as much lift in some cases. Use the snubber for a door stop. It'll get more use.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Adjstable pinion snubber ? [Re: 68LAR] #589739
01/21/10 06:41 PM
01/21/10 06:41 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Also, someone had mentioned that when the snubber was in contact with the body at the top end it felt like the car was "high centered" and leaned the car to one side or the other...No thanks...
Re: Adjstable pinion snubber ? [Re: 68LAR] #589740
01/21/10 07:07 PM
01/21/10 07:07 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
yep,don't use one either,when i punch my pedal the back end raises up
Re: Adjstable pinion snubber ? [Re: Lew] #589741
01/21/10 08:59 PM
01/21/10 08:59 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have mine about 1/2" for the track. I've bent up others in the past, so I make them. I get decent lift at the launch considering the overhang, weight, 3.23 gear, stock converter and the attidude of the car at rest. For what it cost, its worth while
Re: Adjstable pinion snubber ? [Re: Lew] #589742
01/21/10 09:50 PM
01/21/10 09:50 PM
chicagoland,usa
chicagoland,usa
I've used adjustable snubbers on a few cars with springs that were a little on the soft side. All were on lowest setting or even shortened to fit.
Re: Adjstable pinion snubber ? [Re: buildanother] #589743
01/22/10 12:35 AM
01/22/10 12:35 AM
That's what is odd to me.
The only cars they really help (crutch, cough, cough) they don't fit!
With stock springs and the lowest setting you still have to cut the rubber down! I used a cut down upper bump stop on mine.
IIRC, the DC Chassis Manual only recommends them for manual transmission cars anyway?!
Re: Adjstable pinion snubber ? #589744
01/22/10 12:56 AM
01/22/10 12:56 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Lots of people use to run them when you use to have so many Mopars with stock springs. That was before everybody could afford SS springs. They did help keep the pinion from twisting upward and braking ujoints and bolts and with Wheel Hop. I love the SS springs and the way they lift the whole car. Best thing Mopar ever did for suspension. But not very many cars came with them stock.
Re: Adjstable pinion snubber ? #589745
01/22/10 02:11 AM
01/22/10 02:11 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Just sold mine it sat too high at my ride height, actually held the rear of the car up at the lowest setting. I'll be making a custom one if I go back to one again. I will most likely go to Cal-Tracs. The mopar performance work when set up right, but the ride height would be too high for my liking.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMESOX%3AIT
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
