What can i use behind a 5.7 in my 55 Panel? #589648
01/21/10 12:11 AM
01/21/10 12:11 AM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Anyone know what i can use behind the 5.7 hemi. Gonna put it in a 55 Panel. Is the bell housing bolt pattern the same as any previous Motors?
Re: What can i use behind a 5.7 in my 55 Panel? [Re: ejtmopar] #589649
01/21/10 12:59 PM
01/21/10 12:59 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Same as a small block. Check out www.quicktimeinc.com
Re: What can i use behind a 5.7 in my 55 Panel? [Re: rjsjea] #589650
01/21/10 01:33 PM
01/21/10 01:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep use the small block transmission of your choice.
Re: What can i use behind a 5.7 in my 55 Panel? [Re: DaytonaTurbo] #589651
01/21/10 05:10 PM
01/21/10 05:10 PM
plymouth, NH
E
ejtmopar Offline OP
ejtmopar  Offline OP
E
plymouth, NH
Thanks!!
Re: What can i use behind a 5.7 in my 55 Panel? [Re: ejtmopar] #589652
01/21/10 08:59 PM
01/21/10 08:59 PM
Moncton, New Brunswick
hemidart1 Offline
hemidart1  Offline
hy buddy is using a 480LE GM tranny with an adapter in his '57 truck
1967 Hemi GTX
1969 Chrysler 300
Re: What can i use behind a 5.7 in my 55 Panel? [Re: ejtmopar] #589653
01/21/10 09:20 PM
01/21/10 09:20 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
That thing is so high off the ground, if you don't mind messing with the floors a little or setting the motor a little lower, you should consider using the overdrive tranny that came with the 5.7
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: What can i use behind a 5.7 in my 55 Panel? [Re: HealthServices] #589654
01/22/10 08:52 AM
01/22/10 08:52 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Agreed. I like the 5 speed German-junk in the Charger. Nice throttle control. Easy to drive.
Re: What can i use behind a 5.7 in my 55 Panel? [Re: ejtmopar] #589655
01/22/10 09:03 AM
01/22/10 09:03 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
from the looks of it you have a long way to go before you need a trans...I get the body and suspention done (to the right ride height) and then think about what trans you need/want. I'm sure you will have some options.
Coming soon!!!!
