Re: What can i use behind a 5.7 in my 55 Panel?
[Re: ejtmopar]
#589653
01/21/10 09:20 PM
01/21/10 09:20 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
That thing is so high off the ground, if you don't mind messing with the floors a little or setting the motor a little lower, you should consider using the overdrive tranny that came with the 5.7
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
