Hoe to eliminate the 440-1 valley plate #589595
01/20/10 10:42 PM
01/20/10 10:42 PM
lake charles, la
sc4400 Offline OP
sc4400  Offline OP
lake charles, la
I'm tired of poor sealing of the valley plate, and the oil leak that goes with it. I'm thinking of making a gasket/valley plate of .050 aluminum similar to astock steel gasket. Anyone elsr done this? How does it hold up, and any tips or pictures!
RIP
Re: Hoe to eliminate the 440-1 valley plate [Re: sc4400] #589596
01/20/10 10:46 PM
01/20/10 10:46 PM
AndyF Offline
AndyF  Offline
What plate are you using? I use this heavy billet plate and have never had an oil leak.
Re: Hoe to eliminate the 440-1 valley plate [Re: sc4400] #589597
01/21/10 12:13 AM
01/21/10 12:13 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
how are you sealing the valley plat? i've had mine apart lots of times & every rebuild it seals perfect.
Re: Hoe to eliminate the 440-1 valley plate [Re: rebel] #589598
01/21/10 12:24 AM
01/21/10 12:24 AM
hartsburg mo
biggerredz71 Offline
hartsburg mo
The Right Stuff work's good for me.
Re: Hoe to eliminate the 440-1 valley plate [Re: sc4400] #589599
01/21/10 11:09 AM
01/21/10 11:09 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
SC,
This may not be your problem but check the pan to see if there is a hairline crack in one of the re-inforcement beads. Happened to me one time, had the manifold off 3 times before I realized it wasn't a sealing problem.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
