360 block casting question #589427
01/20/10 09:49 PM
01/20/10 09:49 PM
stratford,ontario,canada
JD340 Offline OP
JD340  Offline OP
I've got a 360 block that I'm trying to determine the year of. I can't read the year on the pass side due to a piece of casting flash(I guess) covering the last digit of the year. I can make out 5-8-7?. On the machined pad on the front of the block it's stamped 8W 360 6143. Can anyone help?
Nothing to see here. Carry on.
Re: 360 block casting question [Re: JD340] #589428
01/20/10 10:21 PM
01/20/10 10:21 PM
on the other side the long #, When the so called "thin wall" blocks came out somewhere in the '75 MY they changed the 1st # from a 3 to a 4. That's the best I can offer.
Re: 360 block casting question [Re: RapidRobert] #589429
01/20/10 10:24 PM
01/20/10 10:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Which actually turned into a falasy. Many blocks were independently tested and found many of the later blocks with thicker castings than the early ones. This was on both big and small blocks. Only sure way too tell is to have them sonically tested.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 360 block casting question [Re: MoparforLife] #589430
01/20/10 10:34 PM
01/20/10 10:34 PM
yep that's why I have every prospect sonic checked and never thumb my nose at a later one
Re: 360 block casting question [Re: RapidRobert] #589431
01/20/10 10:39 PM
01/20/10 10:39 PM
JD340 Offline OP
JD340  Offline OP
I DO have that number as well; 4006830-360-3
I also have a partial VIN: 8R257857. The VIN stamp looks like it was poorly done as the 8 is more or less OFF the machined pad on the pan rail. I'm sure this block is nothing special, I'm just trying to get a potential buyer as much info as possible.
Re: 360 block casting question [Re: JD340] #589432
01/20/10 11:03 PM
01/20/10 11:03 PM
Yes 360 blocks are pretty much identical ex the real early ones 71-72/3 something about having a thicker web area and or thicker cyl walls (dont quote me on either of those). Only caveat is the 71-73/4 blocks have different machined area on the #3 thrust main and require a different set of main bearings just for that one bearing (pair). iirc the later bearings will work on both (early/late) but the later main bearings will not work on the early or vice versa. Have him check this out before he orders main bearings. I would not sonic check a 30 over build for a daily driver but anymore than that or any overbore for a performance build I definitely would.
Re: 360 block casting question [Re: JD340] #589433
01/20/10 11:42 PM
01/20/10 11:42 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
4006830 would be a 1976 to 1988 block according to this site with the various casting numbers through the years. However, the Mopar Performance SB book lists that casting number for 1978-1980 360s. On the VIN, "8" might be a 1978 engine, and "R" might mean assembled at the Windsor assembly plant.
Re: 360 block casting question [Re: JD340] #589434
01/21/10 12:12 AM
01/21/10 12:12 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
8=1978
W=Windsor
360=360
I've got a 360 block that I'm trying to determine the year of. ...it's stamped 8W 360 6143. Can anyone help?
Re: 360 block casting question [Re: @#$%&*!] #589435
01/21/10 10:02 AM
01/21/10 10:02 AM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
I too used to be under the impression that all later blocks were super thin wall that couldnt be bored over. I had this crazy block once... the numbers on the sides of it looked like the had been ground off or something. I cant remember everything that was on the front drivers side of the block but I do remember it had 318 there. It had a bore of 4.07 which if I remember right is .030 over 340 pistons. I used the engine for a few months before I sold it. Wish I had hung onto it to figure out what the deal was.
Re: 360 block casting question [Re: derekeh] #589436
01/21/10 11:09 AM
01/21/10 11:09 AM
I had a '75 cordoba with a first #(4) 360 and was upset that it was a thin walled eng until I discovered the aforementioned thin wall debunk.
Re: 360 block casting question [Re: RapidRobert] #589437
01/21/10 11:41 AM
01/21/10 11:41 AM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Its funny that people will bust a nut for 4 bolt mains, steel crank and a block with thick wall castings. Then they build basically a stock engine with cam, headers and intake. I mean honestly does the average joe even come close to pushing the limits of a cast crank engine with a thin wall casting block?
Re: 360 block casting question [Re: derekeh] #589438
01/21/10 12:23 PM
01/21/10 12:23 PM
Upper Midwest
Upper Midwest
NO: NOT EVEN CLOSE! Mopar cast shafts will take more than brand x steel shafts.
Re: 360 block casting question [Re: MoparforLife] #589439
01/21/10 01:04 PM
01/21/10 01:04 PM
magna Offline
magna  Offline
Sorry to nudge in on your post. But I have a 360 with a casting date of 1970. Is that possible? I thought they only casted them from 71 up.
Re: 360 block casting question [Re: magna] #589440
01/21/10 01:12 PM
01/21/10 01:12 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I've seen one with a 69 cast date.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 360 block casting question [Re: magna] #589441
01/21/10 01:12 PM
01/21/10 01:12 PM
Upper Midwest
Upper Midwest
Very likely.71 was the first year as an engine for the car lines but they were all introduced in the fall of 70.
Re: 360 block casting question [Re: MoparforLife] #589442
01/21/10 03:14 PM
01/21/10 03:14 PM
JD340 Offline OP
JD340  Offline OP
Well, between Reggie and Drag Stripper, it looks like I've got my answer! Thanks!!
Re: 360 block casting question [Re: MoparforLife] #589443
01/21/10 04:30 PM
01/21/10 04:30 PM
The MP literature is notoriously inaccurate on when things were introduced (and discontinued). Could generally be a year or 2 off either way. The first # being (4) so called thin wall blocks weren't supposed to have come out until 76 my which why I was dismayed and bent out of shape when I discovered my 1975 cordoba purchase with an oe 360 had a #4 block which means it was cast earlier in '75 or even in 74 then come to discover the "thin wall" myth and all was good especially after I sonic checked it & it was a very thick one .
