Re: 360 block casting question
[Re: JD340]
#589428
01/20/10 10:21 PM
01/20/10 10:21 PM
RapidRobert
on the other side the long #, When the so called "thin wall" blocks came out somewhere in the '75 MY they changed the 1st # from a 3 to a 4. That's the best I can offer.
[Re: RapidRobert]
#589431
01/20/10 10:39 PM
01/20/10 10:39 PM
Posts: 3,547 stratford,ontario,canada
JD340
I DO have that number as well; 4006830-360-3 I also have a partial VIN: 8R257857. The VIN stamp looks like it was poorly done as the 8 is more or less OFF the machined pad on the pan rail. I'm sure this block is nothing special, I'm just trying to get a potential buyer as much info as possible.
Nothing to see here. Carry on.
[Re: JD340]
#589434
01/21/10 12:12 AM
01/21/10 12:12 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
8=1978 W=Windsor 360=360 Quote:
I've got a 360 block that I'm trying to determine the year of. ...it's stamped 8W 360 6143. Can anyone help?
[Re: derekeh]
#589436
01/21/10 11:09 AM
01/21/10 11:09 AM
RapidRobert
I had a '75 cordoba with a first #(4) 360 and was upset that it was a thin walled eng until I discovered the aforementioned thin wall debunk.
[Re: magna]
#589440
01/21/10 01:12 PM
01/21/10 01:12 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I've seen one with a 69 cast date.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: MoparforLife]
#589443
01/21/10 04:30 PM
01/21/10 04:30 PM
RapidRobert
The MP literature is notoriously inaccurate on when things were introduced (and discontinued). Could generally be a year or 2 off either way. The first # being (4) so called thin wall blocks weren't supposed to have come out until 76 my which why I was dismayed and bent out of shape when I discovered my 1975 cordoba purchase with an oe 360 had a #4 block which means it was cast earlier in '75 or even in 74 then come to discover the "thin wall" myth and all was good especially after I sonic checked it & it was a very thick one .
