Quietest best performance muffler suggesions? #58890
05/17/08 12:35 AM
05/17/08 12:35 AM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
I have flowmasters and they are rather loud in the cabin area. Any suggestions on something quie ter without compromising performance.?
Re: Quietest best performance muffler suggesions? [Re: Airgrabber] #58891
05/17/08 02:56 AM
05/17/08 02:56 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Cherry bombs. May not be quietier, but at least we could then hear your car in CA!
I think thrush makes a nice muffler or dynamax for a little more rpm use.
Re: Quietest best performance muffler suggesions? [Re: migsBIG] #58892
05/17/08 03:07 AM
05/17/08 03:07 AM
Texas
TexasStroker Offline
mopar addict
mopar addict
Texas
I've never been a fan of flowmasters...you are probably referring to the resonance that is inside your car.
If you simply want to eliminate the "drone" but keep it loud on the outside, check out some of the flowtech offerings...Extremely under-rated mufflers imo
Likewise, you might be happy with the simple Dynomax Super Turbo...If you really want to keep the flow going look into their UltraFlo line...
Check the mfg sites for clips (should have idle, drive-by, and in car)...Find one you like and then check back here to see if a member has them on their Mopar.
Also what is your engine combo...headers...pipe size...exit location etc? All of these might influence your decision.
Hope that helps a little...
Founder, Amarillo Area Mopars & Lone Star Mopars Amarillo Area Mopars Lone Star Mopars Chryslers in the Canyon: All Mopar Event!
Re: Quietest best performance muffler suggesions? [Re: TexasStroker] #58893
05/17/08 10:15 AM
05/17/08 10:15 AM
pa
ramman16248 Offline
ramman16248  Offline
pa
I bought the flowmaster 50 suv series. They are prety quiet inside and out. (I was a little disappointed at first that they weren't louder.) I had a buddy drive it so I could hear it from the outside, and I think it sounds good when you land on it, just quiet in the interior and at low RPMs.
Re: Quietest best performance muffler suggesions? [Re: ramman16248] #58894
05/17/08 10:26 AM
05/17/08 10:26 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I'm puttin a 5.7 in my GTX and this is what I am going to use
www.corsaperformance.com
This is based on the recomendation of the car builder that is helping me on this project. he says he had an 06 Charget R/T from a client to install a new muffler system so it would sound "badder" than the stock one. They tried 4 major brands, flowmasters,etc, and they all did the resonation thing. The Corsas made the sound right and completely eliminated the resonation.
Worth looking into after an experience like that.
Driving modern convenience in classic beauty
Re: Quietest best performance muffler suggesions? [Re: Airgrabber] #58895
05/18/08 06:31 AM
05/18/08 06:31 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Two DynoMax UltraFlo 'straight through' mufflers spaced the right distance apart
(like the resonator/muffler combo on new Ram pickups)
will be surprisingly quiet with a low rumble
and no drone at highway rpms in the 1500 to 2200 rpm range.
The key measurements are the distances between the mufflers and the length back to the tip from the second muffler.
Re: Quietest best performance muffler suggesions? [Re: 360view] #58896
05/18/08 02:07 PM
05/18/08 02:07 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
I went from 3 chamber Flowmasters to Accurate's "Hemi Repro" muffflers and haven't regreted the switch since. Nice muscular sound without the dreaded "Flowmaster Drone."
Re: Quietest best performance muffler suggesions? [Re: Airgrabber] #58897
05/18/08 02:13 PM
05/18/08 02:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I have flowmasters and they are rather loud in the cabin area. Any suggestions on something quieter without compromising performance.?
Use the largest muffler case size that will fit, regardless of which brand you use. If you can fit a 21"x9" oval muffler, use it instead of a 14"x9".
Personally, the DynoMax Ultra Flow Welded are a faveorite of mine, but I tried the Thrush Welded (basically a cheaper version of the above) and they are quieter with the same basic design.
Re: Quietest best performance muffler suggesions? [Re: In_The_Pink] #58898
05/18/08 02:23 PM
05/18/08 02:23 PM
Canada
RobR Offline
RobR  Offline
Canada
UltraFlows...
Re: Quietest best performance muffler suggesions? [Re: RobR] #58899
05/18/08 03:42 PM
05/18/08 03:42 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
UltraFlows...
Cool vid...
Tell us more about the car!!!!!!
Ultraflows sound great...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Quietest best performance muffler suggesions? [Re: gd9704] #58900
05/18/08 05:22 PM
05/18/08 05:22 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
did you get the "Hemi High Flow" or the "standard Hemi" mufflers ?
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: Quietest best performance muffler suggesions? [Re: bschargerse] #58901
05/18/08 08:26 PM
05/18/08 08:26 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Unlike 98% of the folks here, I too, want a QUIET muscle car.Talk to the folks at Dynomax, I ran the 3" long case Hemi reverse flow(17769, I think)on my car and they were fairly quiet, the engineer I talked to said they only gave up 5 horses to their ultra-flows which are considerably louder. I would talk to Accurate also, I know I will next time. Nothing like staging quietly next to a loud car and stompin a mudhole in 'em. Lee.
Re: Quietest best performance muffler suggesions? [Re: Lee446] #58902
05/18/08 08:35 PM
05/18/08 08:35 PM
dont get the hooker aero chamber.cruising their
not bad,put your foot in it and they'll blow your ears out.
Re: Quietest best performance muffler suggesions? #58903
05/18/08 08:47 PM
05/18/08 08:47 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
thry all can be loud. imo feed the collector to a glasspack, and after the glasspack and axle install the muffler. or vice-versa.
Re: Quietest best performance muffler suggesions? [Re: mark7171] #58904
05/19/08 12:21 AM
05/19/08 12:21 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Dynomax Turbo. Sweet.
Re: Quietest best performance muffler suggesions? [Re: DennisH ] #58905
05/19/08 10:26 AM
05/19/08 10:26 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
X-pipe + Dynomax Ultraflows = No Droan
Re: Quietest best performance muffler suggesions? [Re: bschargerse] #58906
05/20/08 12:34 AM
05/20/08 12:34 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I was going to purchase the "standard hemi" mufflers from Accurate and they talked me into the " High Flow" mufflers.. I expressed to them that I did not want a loud muffler.. They told me I would be happy with the High Flow.. Wish I could tell you how they sound, but I haven't started it yet..
Re: Quietest best performance muffler suggesions? [Re: minivan] #58907
05/20/08 01:18 AM
05/20/08 01:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
DynoMax "Hemi" SuperTurbo. Simular to the regular SuperTurbo, but a bigger case and a bit quieter.
In Car Craft, about 15 years ago, it was rated as one of the best flowing mufflers, and I think the quietest when they did a muffler comparison story.
I'm Not sure if Sears still sells the Walker "Hemi" replacement muffler, but it sounded really nice too. No sure how it flowed.
Re: Quietest best performance muffler suggesions? [Re: 451Mopar] #58908
05/20/08 07:31 AM
05/20/08 07:31 AM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
The Walker Quiet Flow replacement muffler for B-bodies with a big block is part #21848. The economy version is part #18230. 2-1/4" inlet and outlet. The Walker catalog list this # for both the 383 and the 440. Rock Auto has the #21848 for $49, my local Napa wants $70 each. Walker does have a $50 rebate until May 31 on Quiet Flow mufflers. I don't know if this may be a problem or not, this muffler is made to fit other vehicles too, it also fits Chevy Astro vans, and older Buick LeSabres, so it might not have that Mopar sound.
Re: Quietest best performance muffler suggesions? [Re: DennisH ] #58909
05/20/08 10:27 AM
05/20/08 10:27 AM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
I love mine....get comments all the time.
