440 distributor #588913
01/20/10 07:45 PM
01/20/10 07:45 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
I just purchased a distributor on ebay item #230422363671 for my 70 Dodge challenger 440 4 barrel 4spd. After getting it I realized it might be incorrect. The red anodized tag reads the 3438222 which is correct but the date is 6 9 which in my mind is for a 69 build and the vacuum advance part # is 2642262. Does anyone know if this is correct or can I use the distributor and change the advance and put a repro date correct tag on it? I would even consider purchasing a correct one if there is one available.
1965 GTO 4 spd tripower convert 1966 GTO 4 spd a/c factory red on red 1969 1/2 Superbee 4 spd butterscotch 1970 Challenger RT 440 4 spd factory black on black
Re: 440 distributor [Re: tx9440] #588914
01/21/10 08:43 AM
01/21/10 08:43 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
IIRC, a 440 4-speed in '70 should have had the Prestolite dual-point distributor. That's a Prestolite vacuum advance pod, but the distributor itself is a Chrysler version. After reading his ad and him claiming it's even for a v-code, that's absolutely wrong. Again, the iron Prestolite dual-point is for a '70 v-code and 4-speed u-code. The automatic u-codes would come with the Chrysler single-point and the v-code autos, again, would come with the Prestolite.
Maybe I'm wrong, but I know for a fact a 440 4speed car in '69 would have the dual point.
Troy
Troy
Houston Mopar Connection Club
Re: 440 distributor [Re: hemi68charger] #588915
01/21/10 10:03 AM
01/21/10 10:03 AM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
Based on the info I have in my books all 440 4 barrels will have a single point distributor regardless of the tranny type. He had told me the vacuum advance changed mid year and went to an electronic one. Do not know if this is correct.
Re: 440 distributor [Re: tx9440] #588916
01/21/10 10:19 AM
01/21/10 10:19 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
1969,
440 auto, single point
440 4spd dual point
69 1/2 both dual point
1970,
440 4spd single point
440 auto single point
440 6pk dual both.
6/9 date code is June,a little early but possible.
These are both are 70 6pk,early on right,late on left.
Also,Troy if that is a picture of a 69 engine,it has the wrong vacuum advance.
Re: 440 distributor [Re: 62maxwgn] #588917
01/21/10 10:51 AM
01/21/10 10:51 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
That should be a '70-1 440 since it has the 1/2" and 5/8" heater hose fittings. '69 would be 5/8"- 5/8"
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 440 distributor [Re: 70440+6bbl] #588918
01/21/10 10:55 AM
01/21/10 10:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I woild suspect that is a Hemi as to the fuel line tee,where the coil is mounted and the bracket's.
Re: 440 distributor [Re: 62maxwgn] #588919
01/21/10 11:05 AM
01/21/10 11:05 AM
Houston, Tx
Houston, Tx
It's a hemi. I was trying to convey the Prestolite body versus the Chrysler.
Nice to know I'm still learning. So, '70 would have been single point as well for a 440 auto or 4-speed. My experiences with '70 models on both my '70 Chargers R/T were v-codes and '69 440 speeds, hence my bias towards dual-breaker distributor application and my false assumption the '70 model year would have followed suit for the 440 4-speed cars.
But, would the '70 distributor pictured in the original guestion have the Prestolite-style advance or the more traditional Chrysler?
Troy
Troy
Re: 440 distributor [Re: hemi68charger] #588920
01/21/10 11:18 AM
01/21/10 11:18 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I have owned several of the 3438222 distributors over the years and they all had the electronic retard canister like this 222 dizzy in a '70 u-code New Yorker.
Re: 440 distributor [Re: tx9440] #588921
01/21/10 11:26 AM
01/21/10 11:26 AM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
70/71 440-4 bbl 4 sp or auto should have a single point distributor and vacuum advance w/electronic box.
Ken
Re: 440 distributor [Re: hemi_tyme] #588922
01/21/10 11:46 AM
01/21/10 11:46 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ken
Just like this.
Re: 440 distributor [Re: 62maxwgn] #588923
01/21/10 11:51 AM
01/21/10 11:51 AM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
Ken
Just like this.
Yes, or tan colored box
Re: 440 distributor [Re: hemi_tyme] #588924
01/21/10 12:30 PM
01/21/10 12:30 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
Can I use the distributor I have and change the vacuum and will it then be 100% correct looking or should I buy another one. If buying one is the better option does anyone know where I can get it.
Re: 440 distributor [Re: tx9440] #588925
01/21/10 01:13 PM
01/21/10 01:13 PM
NJ
moparply Offline
moparply  Offline
NJ
You need to change the vacumm canister. They are available in used and NOS, I might have an extra.
Re: 440 distributor [Re: tx9440] #588926
01/21/10 01:16 PM
01/21/10 01:16 PM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
Pm sent
Re: 440 distributor [Re: tx9440] #588927
01/21/10 01:20 PM
01/21/10 01:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually,with the distributor you show I don't know how they got the vacuum advance connected.That is a Prestolite advance,it has a arm with a hole that mounts to a pin on the breaker plate,the distributor you show is a Chrysler unit which is just the opposite,the stud on the arm goes in a hole on the breaker plate.You can use the distributor you have with the above vacuum unit I posted as long as it has the correct breaker plate.I'd like to see a picture of that plate.
Re: 440 distributor [Re: 62maxwgn] #588928
01/21/10 01:35 PM
01/21/10 01:35 PM
Houston, Tx
Houston, Tx
I just installed a single-breaker in my 440 auto Daytona and it works fine... I wanted the motor to be more correct.
Troy
Re: 440 distributor [Re: hemi68charger] #588929
01/21/10 01:58 PM
01/21/10 01:58 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
Here is a picture of the arm and plate.
Re: 440 distributor [Re: tx9440] #588930
01/21/10 02:18 PM
01/21/10 02:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Havn't a clue as to the Prestolite vacuum advance with the distributor cap locating tabs.Here are the only variations I have seen.Only one is Prestolite,the others are Chrysler.Have never seen a Prestolite unit on a Chrysler distributor. The Chrysler unit with the electronic unit as pictured is the correct one for the 70 440 4spd.
Re: 440 distributor [Re: 62maxwgn] #588931
01/21/10 02:23 PM
01/21/10 02:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And if you have the correct 4737 AVS 4spd carb,it should have this solenoid and bracket to work in conjunction with the distributor.
Re: 440 distributor [Re: 62maxwgn] #588932
01/21/10 02:34 PM
01/21/10 02:34 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
It appears to be correct I just do not have the wire. Is there a repro avaiable.
