440 distributor
#588913
01/20/10 07:45 PM
01/20/10 07:45 PM
Posts: 15 new york
tx9440
new york
I just purchased a distributor on ebay item #230422363671 for my 70 Dodge challenger 440 4 barrel 4spd. After getting it I realized it might be incorrect. The red anodized tag reads the 3438222 which is correct but the date is 6 9 which in my mind is for a 69 build and the vacuum advance part # is 2642262. Does anyone know if this is correct or can I use the distributor and change the advance and put a repro date correct tag on it? I would even consider purchasing a correct one if there is one available.
1965 GTO 4 spd tripower convert
1966 GTO 4 spd a/c factory red on red
1969 1/2 Superbee 4 spd butterscotch
1970 Challenger RT 440 4 spd factory black on black
Re: 440 distributor
[Re: tx9440]
#588914
01/21/10 08:43 AM
01/21/10 08:43 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
IIRC, a 440 4-speed in '70 should have had the Prestolite dual-point distributor. That's a Prestolite vacuum advance pod, but the distributor itself is a Chrysler version. After reading his ad and him claiming it's even for a v-code, that's absolutely wrong. Again, the iron Prestolite dual-point is for a '70 v-code and 4-speed u-code. The automatic u-codes would come with the Chrysler single-point and the v-code autos, again, would come with the Prestolite.
Maybe I'm wrong, but I know for a fact a 440 4speed car in '69 would have the dual point.
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 440 distributor
[Re: hemi68charger]
#588915
01/21/10 10:03 AM
01/21/10 10:03 AM
Posts: 15 new york
tx9440
new york
Based on the info I have in my books all 440 4 barrels will have a single point distributor regardless of the tranny type. He had told me the vacuum advance changed mid year and went to an electronic one. Do not know if this is correct.
Re: 440 distributor
[Re: tx9440]
#588916
01/21/10 10:19 AM
01/21/10 10:19 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
1969, 440 auto, single point 440 4spd dual point 69 1/2 both dual point
1970, 440 4spd single point 440 auto single point 440 6pk dual both.
6/9 date code is June,a little early but possible.
These are both are 70 6pk,early on right,late on left.
Also,Troy if that is a picture of a 69 engine,it has the wrong vacuum advance.
Re: 440 distributor
[Re: 70440+6bbl]
#588918
01/21/10 10:55 AM
01/21/10 10:55 AM
62maxwgn
Blair County,PA
That should be a '70-1 440 since it has the 1/2" and 5/8" heater hose fittings. '69 would be 5/8"- 5/8"
I woild suspect that is a Hemi as to the fuel line tee,where the coil is mounted and the bracket's.
Re: 440 distributor
[Re: 62maxwgn]
#588919
01/21/10 11:05 AM
01/21/10 11:05 AM
hemi68charger
Houston, Tx
It's a hemi. I was trying to convey the Prestolite body versus the Chrysler.
Nice to know I'm still learning. So, '70 would have been single point as well for a 440 auto or 4-speed. My experiences with '70 models on both my '70 Chargers R/T were v-codes and '69 440 speeds, hence my bias towards dual-breaker distributor application and my false assumption the '70 model year would have followed suit for the 440 4-speed cars.
But, would the '70 distributor pictured in the original guestion have the Prestolite-style advance or the more traditional Chrysler?
Troy
Re: 440 distributor
[Re: hemi68charger]
#588920
01/21/10 11:18 AM
01/21/10 11:18 AM
Posts: 5,268 NY
70440+6bbl
NY
I have owned several of the 3438222 distributors over the years and they all had the electronic retard canister like this 222 dizzy in a '70 u-code New Yorker.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 440 distributor
[Re: hemi_tyme]
#588922
01/21/10 11:46 AM
01/21/10 11:46 AM
62maxwgn
Blair County,PA
70/71 440-4 bbl 4 sp or auto should have a single point distributor and vacuum advance w/electronic box. Ken
Just like this.
Re: 440 distributor
[Re: 62maxwgn]
#588923
01/21/10 11:51 AM
01/21/10 11:51 AM
Posts: 532 Central,AR
hemi_tyme
Central,AR
Just like this.
Yes, or tan colored box
Re: 440 distributor
[Re: hemi_tyme]
#588924
01/21/10 12:30 PM
01/21/10 12:30 PM
Posts: 15 new york
tx9440
new york
Can I use the distributor I have and change the vacuum and will it then be 100% correct looking or should I buy another one. If buying one is the better option does anyone know where I can get it.
Re: 440 distributor
[Re: tx9440]
#588927
01/21/10 01:20 PM
01/21/10 01:20 PM
62maxwgn
Blair County,PA
Actually,with the distributor you show I don't know how they got the vacuum advance connected.That is a Prestolite advance,it has a arm with a hole that mounts to a pin on the breaker plate,the distributor you show is a Chrysler unit which is just the opposite,the stud on the arm goes in a hole on the breaker plate.You can use the distributor you have with the above vacuum unit I posted as long as it has the correct breaker plate.I'd like to see a picture of that plate.
Re: 440 distributor
[Re: 62maxwgn]
#588928
01/21/10 01:35 PM
01/21/10 01:35 PM
hemi68charger
Houston, Tx
I just installed a single-breaker in my 440 auto Daytona and it works fine... I wanted the motor to be more correct.
Re: 440 distributor
[Re: hemi68charger]
#588929
01/21/10 01:58 PM
01/21/10 01:58 PM
Posts: 15 new york
tx9440
new york
Here is a picture of the arm and plate.
Re: 440 distributor
[Re: 62maxwgn]
#588932
01/21/10 02:34 PM
01/21/10 02:34 PM
Posts: 15 new york
tx9440
new york
It appears to be correct I just do not have the wire. Is there a repro avaiable.
