vacuumhose #588419
01/20/10 01:46 PM
01/20/10 01:46 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
is there any of you using Promax metering blocks that can tell me where I shall put vacuumhose for ignition, has written to Promax, but they do not respond.
Re: vacuumhose [Re: kennetto] #588420
01/20/10 02:00 PM
01/20/10 02:00 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I would suggest that you call Ben directly instead of email. (317-484-1451) I get a quicker response by calling.
Re: vacuumhose [Re: YO7_A66] #588421
01/20/10 02:06 PM
01/20/10 02:06 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
I'm not so good at talking your language
Re: vacuumhose [Re: kennetto] #588422
01/20/10 02:10 PM
01/20/10 02:10 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Not a problem. Maybe give Ben some more time to respond. He usually gets back with me in a day or so on email.
Re: vacuumhose [Re: YO7_A66] #588423
01/20/10 04:54 PM
01/20/10 04:54 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
anyone
Re: vacuumhose [Re: kennetto] #588424
01/20/10 05:23 PM
01/20/10 05:23 PM
I dont own one but trying to help. I'm assuming that they dont have a stock (ported) fitting on the side like stock holley metering blocks do?
Re: vacuumhose [Re: RapidRobert] #588425
01/21/10 04:22 AM
01/21/10 04:22 AM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
yes it is correct no fitting on the side.
Re: vacuumhose [Re: kennetto] #588426
01/21/10 08:45 AM
01/21/10 08:45 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
they dont have a ported vacuum fitting on them
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: vacuumhose [Re: aarcuda] #588427
01/21/10 09:41 AM
01/21/10 09:41 AM
scratchnfotraction Offline
hook it to the intake manifold for full vac maybe
use a carb spacer that has a port for vac line
timed port may not be an easy thing to add if it does not already have it
Re: vacuumhose [Re: scratchnfotraction] #588428
01/21/10 02:13 PM
01/21/10 02:13 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
is it just me who has bought promax meteringblock
Re: vacuumhose [Re: kennetto] #588429
01/22/10 05:12 PM
01/22/10 05:12 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
I guess it was wasted money to buy Promax metering blocks, If i will have Vacuum to the distrubutor I have to take it out and put back my old original holley.
Re: vacuumhose [Re: kennetto] #588430
01/22/10 05:33 PM
01/22/10 05:33 PM
Might experiment w manifold vacuum & see if you can get it to work. Yes I (& most) prefer ported but above idle the amt would be the same so I would think you could get it to work & therefore not waste your (Promax) investment and a carb guru might be able to talk you thru drilling the base to add ported. Good luck on it. EDIT or possibly drilling the Promax. I'd think there'd be a (ported) source inside there somewhere. I am not a carb guy. Have you emailed Promax.
Re: vacuumhose [Re: kennetto] #588431
01/22/10 05:43 PM
01/22/10 05:43 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Well, I would'nt go as far to say it was a waste in buying the metering block...You do have a high performance engine that needs the block right ???? You don't need the distributor advance for a performance engine...If the engine is close to stock and you want the fuel economy of the distributor vacuum advance then that's a different story...I run the Promax block and don't need/use the vacuum advance...For all out performance it's not needed... I was thinking about adding the channel to the promax block just as an experiment but that's all it would be....Here's a link to a previous thread that shows the mods needed to add the vacuum port...Not a small job... link ...The vacuum advance comes into play at part throttle or cruizing RPM so the spark has more time to completely burn the fuel...You'll get a little more distance out of your fuel but who cares about that when your ...
Re: vacuumhose [Re: screamindriver] #588432
01/23/10 05:27 AM
01/23/10 05:27 AM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
thanks for your svar.ja I have written to Promax 2 times no response, it is probably best if I remove Promax block the car runs best on the street and our gasoline prices here in Sweden is more than double the era so I do Vacum igniti
Tack för att du bidrar med ditt översättningsförslag till Google Översätt
thanks for your response.yes I have written to Promax 2 times no response, it is probably best if I remove the Promax block and use the old holley, the car runs most on the street and our gasoline prices here in Sweden is more than double yours so I do need Vacuum advance.
