Re: Wiring an A-500 over drive
[Re: prodak87]
#588312
01/20/10 02:24 PM
01/20/10 02:24 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Go to Performance Transmission web site. Everything you wanted to know and more. Also parts to do lock up and overdrive automatically based on engine vacuum. http://www.transmissioncenter.net/SwapInformation.htmCraig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: prodak87]
#588314
01/20/10 11:52 PM
01/20/10 11:52 PM
denfireguy
Colorado
Yes, they are the same. Craig
[Re: prodak87]
#588316
01/21/10 01:29 PM
01/21/10 01:29 PM
Posts: 2,255 IL
furious70
IL
I have found it very useful to separate OD and lockup in my a-500. I have 1 switch that kills both and a second switch that will allow OD but not lockup. I have the vac. switch for kickdown as well as the adjustable pressure switches on the tranny to set the upshift speeds. IMO all of that is required to tune it to your vehicles needs and your tastes. I have 3.91's and 28" tires, I have it set to hit OD about 45mph and lockup at 55, those I very often keep lockup turned off unless I'm on the interstate. Even with 3.91's it tends to bog a bit, if I had 4.10's or def. 4.30/56's I'd let it sit up in lockup all the time (or if I had short tires)
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#588317
01/21/10 02:38 PM
01/21/10 02:38 PM
Posts: 22 IL.
prodak87
IL.
[Re: prodak87]
#588318
01/21/10 02:57 PM
01/21/10 02:57 PM
Posts: 2,255 IL
furious70
IL
hassle? Not really, the OD just needs tuning like a new carb or anything else. I'm very happy with mine - off the line like a 4.30 gear with the low 1/2 set and down the road at 2.68 + lockup. It's both a performance and economy upgrade in 1 tidy package. Mine was done by Tranztech in Dubuque, Ia, quite reasonably for a turn key job.
