Looking for rear disc for a 8.75 drag car #588010
01/19/10 10:27 PM
01/19/10 10:27 PM
Brantford On Canada
Rampage16v Offline OP
Brantford On Canada
Looking for rear brakes for my drag daytona whether it be a wildwood style set up or a good lighter factory type set or an easy way to adapt late model rear discs
Dean Stillie 82 Rampage 2.4 litre turbo [Email]10.14@138.02[/Email] mph
Re: Looking for rear disc for a 8.75 drag car [Re: Rampage16v] #588011
01/19/10 11:18 PM
01/19/10 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I got mine direct from Mopar ... it was a Wilwood
set up... might give them a call
Re: Looking for rear disc for a 8.75 drag car [Re: Rampage16v] #588012
01/20/10 02:58 PM
01/20/10 02:58 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
contact Dr. Diff.
Re: Looking for rear disc for a 8.75 drag car [Re: JUST_N_TIME] #588013
01/20/10 03:24 PM
01/20/10 03:24 PM
K
Kiddart Offline
Kiddart  Offline
K
I have the same question, I am sure one of you very briliant guys and I mean this with all do respect, hasnt come up with a home made conversion kit for a 8 3/4 rear end. Some has to have don this with a few bar napkin sketches and the parts they used??
Thank you
Kiddart
Re: Looking for rear disc for a 8.75 drag car [Re: Kiddart] #588014
01/20/10 04:28 PM
01/20/10 04:28 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I thought I read on here a while back where someone used parts of a Jeep Cherokee or similar...
Re: Looking for rear disc for a 8.75 drag car [Re: Sixpak] #588015
01/20/10 04:31 PM
01/20/10 04:31 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
A dana 60 and a 8 3/4 is the same. there are tons of kits available.
Re: Looking for rear disc for a 8.75 drag car [Re: joshking440] #588016
01/20/10 10:06 PM
01/20/10 10:06 PM
K
Kiddart Offline
Kiddart  Offline
K
Sixpac some one did and I think it was on a Dana, I am loooking for the thread but cant find it. it was using a jeep disc and I think a next generation Caliper, Not sure but I will find it it was a very short post to the thread. If any one else finds it please add to this so we can make a contact.
Thank you
Kiddart
Re: Looking for rear disc for a 8.75 drag car [Re: Kiddart] #588017
01/20/10 10:51 PM
01/20/10 10:51 PM
AndyF Offline
AndyF  Offline
DoctorDiff has a good rear disc kit. It keeps the tapered roller bearings and it installs easily.
Re: Looking for rear disc for a 8.75 drag car [Re: AndyF] #588018
01/20/10 11:16 PM
01/20/10 11:16 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Wilwood on my 8 3/4 and on the front.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Looking for rear disc for a 8.75 drag car [Re: 11secdart] #588019
01/20/10 11:41 PM
01/20/10 11:41 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
There is a kit that uses a weld on bracket.I think it is a Ford calipers and disc.A customer bought this and Did not use.It is a complete kit with new lines,calipers,and disc.
Will take $200. plus shipping
Re: Looking for rear disc for a 8.75 drag car [Re: 8secDart] #588020
01/20/10 11:58 PM
01/20/10 11:58 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
1993 Jeep Grand Cherokee rotors.. GM metric calipers and weld on brackets. Less than $200 when your done...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Looking for rear disc for a 8.75 drag car [Re: DemonDust] #588021
01/21/10 12:12 AM
01/21/10 12:12 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Got any part numbers?
Re: Looking for rear disc for a 8.75 drag car [Re: 9 Sec Phill] #588022
01/21/10 12:25 AM
01/21/10 12:25 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
No sorry, but the rotors were the economy ones for like 17.99. The calipers are for 82 malibu and brackets are from speed way...
SDG Motorsports
Re: Looking for rear disc for a 8.75 drag car [Re: DemonDust] #588023
01/21/10 12:32 AM
01/21/10 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem with this is that its big old heavy parts,
I'll stick with my light weight Wilwood set up, it
uses 1/4 thick vented rotors and light calipers
Re: Looking for rear disc for a 8.75 drag car [Re: MR_P_BODY] #588024
01/21/10 06:13 AM
01/21/10 06:13 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I also did the Speedway brackets, GM Metric calipers and Grand Cherokee rotors. My rotors are from a 2000 front. I agree they are kind of on the heavy side, but they are cheap and you can buy everything except the brackets at the local part store.
Re: Looking for rear disc for a 8.75 drag car [Re: Dartin] #588025
01/21/10 09:37 AM
01/21/10 09:37 AM
Georgia
moparjimbo60 Offline
Georgia
i agree they might be a tad heavier than the wildwood, but much cheaper, i did the same thing but i used dakota rotors i think. had to have a big hole in the center for strange axles. got 150.00 in all of it, with braided lines. works great and is still alot less wieght than the drums, backing plates ..ect.........
Re: Looking for rear disc for a 8.75 drag car [Re: moparjimbo60] #588026
01/21/10 09:59 AM
01/21/10 09:59 AM
Hemiroid Offline
Hemiroid  Offline
A tad heavier? LOL, they're a lot heavier, and not much lighter than drums. The drums also stop as good and maybe better, so without the weight savings what's the point?
Re: Looking for rear disc for a 8.75 drag car [Re: Hemiroid] #588027
01/21/10 10:05 AM
01/21/10 10:05 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I lost 50lbs off the rear going from an 11 inch drum setup to a Wilwood setup.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Looking for rear disc for a 8.75 drag car [Re: 11secdart] #588028
01/21/10 11:00 AM
01/21/10 11:00 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My entire 11" set up only weighed 54#, the street Wilwood kit with the internal parking brake
weighed 38#.
Re: Looking for rear disc for a 8.75 drag car [Re: justinp61] #588029
01/21/10 11:14 AM
01/21/10 11:14 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Does anyone else run a parking/emergency brake?
Chris from New Jersey
