Looking for rear disc for a 8.75 drag car
#588010
01/19/10 10:27 PM
01/19/10 10:27 PM
Posts: 35 Brantford On Canada
Rampage16v
Brantford On Canada
Looking for rear brakes for my drag daytona whether it be a wildwood style set up or a good lighter factory type set or an easy way to adapt late model rear discs
Dean Stillie
82 Rampage
2.4 litre turbo
[Email]10.14@138.02[/Email] mph
Re: Looking for rear disc for a 8.75 drag car
[Re: JUST_N_TIME]
#588013
01/20/10 03:24 PM
01/20/10 03:24 PM
Posts: 1,552 Michigan
Kiddart
I have the same question, I am sure one of you very briliant guys and I mean this with all do respect, hasnt come up with a home made conversion kit for a 8 3/4 rear end. Some has to have don this with a few bar napkin sketches and the parts they used??
Thank you Kiddart
[Re: joshking440]
#588016
01/20/10 10:06 PM
01/20/10 10:06 PM
Kiddart
Sixpac some one did and I think it was on a Dana, I am loooking for the thread but cant find it. it was using a jeep disc and I think a next generation Caliper, Not sure but I will find it it was a very short post to the thread. If any one else finds it please add to this so we can make a contact.
Thank you Kiddart
[Re: Kiddart]
#588017
01/20/10 10:51 PM
01/20/10 10:51 PM
Posts: 31,050 Oregon
AndyF
DoctorDiff has a good rear disc kit. It keeps the tapered roller bearings and it installs easily.
[Re: AndyF]
#588018
01/20/10 11:16 PM
01/20/10 11:16 PM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
Wilwood on my 8 3/4 and on the front.
[Re: 9 Sec Phill]
#588022
01/21/10 12:25 AM
01/21/10 12:25 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Got any part numbers?
No sorry, but the rotors were the economy ones for like 17.99. The calipers are for 82 malibu and brackets are from speed way...
[Re: DemonDust]
#588023
01/21/10 12:32 AM
01/21/10 12:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
1993 Jeep Grand Cherokee rotors.. GM metric calipers and weld on brackets. Less than $200 when your done...
The problem with this is that its big old heavy parts, I'll stick with my light weight Wilwood set up, it uses 1/4 thick vented rotors and light calipers
[Re: Dartin]
#588025
01/21/10 09:37 AM
01/21/10 09:37 AM
Posts: 200 Georgia
moparjimbo60
Georgia
I also did the Speedway brackets, GM Metric calipers and Grand Cherokee rotors. My rotors are from a 2000 front. I agree they are kind of on the heavy side, but they are cheap and you can buy everything except the brackets at the local part store.
i agree they might be a tad heavier than the wildwood, but much cheaper, i did the same thing but i used dakota rotors i think. had to have a big hole in the center for strange axles. got 150.00 in all of it, with braided lines. works great and is still alot less wieght than the drums, backing plates ..ect.........
[Re: moparjimbo60]
#588026
01/21/10 09:59 AM
01/21/10 09:59 AM
Posts: 705 Michigan
Hemiroid
A tad heavier? LOL, they're a lot heavier, and not much lighter than drums. The drums also stop as good and maybe better, so without the weight savings what's the point?
[Re: Hemiroid]
#588027
01/21/10 10:05 AM
01/21/10 10:05 AM
11secdart
new jersey usa
I lost 50lbs off the rear going from an 11 inch drum setup to a Wilwood setup.
[Re: 11secdart]
#588028
01/21/10 11:00 AM
01/21/10 11:00 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My entire 11" set up only weighed 54#, the street Wilwood kit with the internal parking brake weighed 38#.
[Re: justinp61]
#588029
01/21/10 11:14 AM
01/21/10 11:14 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Does anyone else run a parking/emergency brake?
Chris from New Jersey
