Quest for the tens. One move at a time...
#587734
01/19/10 05:14 PM
01/19/10 05:14 PM
Posts: 150 South Carolina, United States
carolinacuda
Whats up fellas. Im sure im in the same boat as alot of yall. Very little $$ and I cant afford to make all the changes I neeed to so you make one change at a time. So you try to pick the right move when you do get some $. Like alot of street guys I want to see tens. So far my best is 11.49 @118mph with a 1.55 60ft. It's a 74 cuda with a basic 440, stock susp with 275 M/T street radials. 90/10's up front and clamped springs with snubber in rear. More info on motor. 446 with trw's, Indy Ez's stock port, Vict Int, 850 demon, Hughes solid flat 572/579 252/256 @50 cam, 3.91gears and TCI 3800 stall. Hooker Comp headers with 3' exhaust. I regret some things I've done and like some things as well. This spring I plan on making some more changes as i do every year. Just not sure whats next. Motor work, Susp upgrades, different Stall, head porting. Just cant afford to do it all yet. Am i running ok with what i got? seen guys with more run less and guys with less run faster. What would be my most benefecial move. Your is appreciated here.
Re: Quest for the tens. One move at a time...
[Re: Hemiroid]
#587737
01/19/10 05:56 PM
01/19/10 05:56 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
I'd be taking a long, hard look at the converter. I've never had much luck with TCI personally. Converters make or break combos and I believe a quality converter purpose built for your combo with more stall speed will pick your combo up.
It will cost you about 1k for a good converter. But its money well spent! Drop the 60' times and the rest will soon follow ....Phill
[Re: 8secDart]
#587741
01/19/10 08:55 PM
01/19/10 08:55 PM
Snubber and converter in the trash.Call Kenny at PTC for a converter.A good port job.Should put it right in the 10s.
100%.......and I'd do the porting last.....PTC does a great job, although what they send is usually on the tight side......so I typically ask for something about 500RPM higher than what I want.....
If you can go 120MPH, it can get into the 10's......and with a better converter, it'll ET better and I bet it'll pick up 1 or 2MPH, so you should be close.......
[Re: carolinacuda]
#587744
01/19/10 11:03 PM
01/19/10 11:03 PM
Posts: 691 ohio
1Bad440
ohio
How heavy is it? I would think that combo should be knocking at the 10 sec zone if it was sorted out.
[Re: 440dart]
#587745
01/19/10 11:13 PM
01/19/10 11:13 PM
I would look at head porting, before the convertor
converter at your power range isnt going to make or break it. you need to port those heads to flow much better to pickup.head flow produces hp. i picked up .4 from a bogus hemi head flowing 378 to 450 cfm. nothing else.
[Re: mikeysmopars]
#587746
01/19/10 11:16 PM
01/19/10 11:16 PM
Im gonna borrow from the import guys on this one and say slap some stickers on it! Every import ive seen at a car show that had stickers on it the owner told me it ran 9s or 10s. Cheap hp in my book!
There's always ONE! Thats Great! I say open those heads and force it out, The converter will think it bigger!
absolutely this is true.
[Re: carolinacuda]
#587748
01/19/10 11:50 PM
01/19/10 11:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Right now your .3 slow based on the MPH, that would suggest a chassis issue... but it could be a fuel issue also if your running out on the top end... I would try to find out whats wrong now
[Re: MR_P_BODY]
#587749
01/20/10 12:11 AM
01/20/10 12:11 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
sounds like a street car.....I'll bet the converter is the one thing you can change and see big results. Is this a 10" converter...thats the biggest compromise in most street cars (mine included)?
