Quest for the tens. One move at a time... #587734
01/19/10 05:14 PM
01/19/10 05:14 PM
South Carolina, United States
carolinacuda Offline OP
Whats up fellas. Im sure im in the same boat as alot of yall. Very little $$ and I cant afford to make all the changes I neeed to so you make one change at a time. So you try to pick the right move when you do get some $. Like alot of street guys I want to see tens. So far my best is 11.49 @118mph with a 1.55 60ft. It's a 74 cuda with a basic 440, stock susp with 275 M/T street radials. 90/10's up front and clamped springs with snubber in rear. More info on motor. 446 with trw's, Indy Ez's stock port, Vict Int, 850 demon, Hughes solid flat 572/579 252/256 @50 cam, 3.91gears and TCI 3800 stall. Hooker Comp headers with 3' exhaust. I regret some things I've done and like some things as well. This spring I plan on making some more changes as i do every year. Just not sure whats next. Motor work, Susp upgrades, different Stall, head porting. Just cant afford to do it all yet. Am i running ok with what i got? seen guys with more run less and guys with less run faster. What would be my most benefecial move. Your is appreciated here.
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587735
01/19/10 05:52 PM
01/19/10 05:52 PM
Hemiroid Offline
Hemiroid  Offline
I'd be taking a long, hard look at the converter. I've never had much luck with TCI personally. Converters make or break combos and I believe a quality converter purpose built for your combo with more stall speed will pick your combo up.
Re: Quest for the tens. One move at a time... [Re: Hemiroid] #587736
01/19/10 05:53 PM
01/19/10 05:53 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: Quest for the tens. One move at a time... [Re: Hemiroid] #587737
01/19/10 05:56 PM
01/19/10 05:56 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
It will cost you about 1k for a good converter. But its money well spent! Drop the 60' times and the rest will soon follow ....Phill
Re: Quest for the tens. One move at a time... [Re: QWK_ENUF] #587738
01/19/10 05:59 PM
01/19/10 05:59 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
I would look at head porting, before the convertor
Yes I live in Michigan, so there is still 1 light on
Re: Quest for the tens. One move at a time... [Re: 440dart] #587739
01/19/10 06:45 PM
01/19/10 06:45 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I vote converter, first and foremost, too!
You don't have to spend a grand...if you want to keep the car streetable, call Dynamic (Frank Lupo) and order a 9.5" for your combo. I think they're around $600. Or watch for a used (from a trusted seller) 8" if more race only.
Re: Quest for the tens. One move at a time... [Re: cudadoug] #587740
01/19/10 07:51 PM
01/19/10 07:51 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Snubber and converter in the trash.Call Kenny at PTC for a converter.A good port job.Should put it right in the 10s.
Re: Quest for the tens. One move at a time... [Re: 8secDart] #587741
01/19/10 08:55 PM
01/19/10 08:55 PM
100%.......and I'd do the porting last.....PTC does a great job, although what they send is usually on the tight side......so I typically ask for something about 500RPM higher than what I want.....
If you can go 120MPH, it can get into the 10's......and with a better converter, it'll ET better and I bet it'll pick up 1 or 2MPH, so you should be close.......
Re: Quest for the tens. One move at a time... #587742
01/19/10 09:49 PM
01/19/10 09:49 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Im gonna borrow from the import guys on this one and say slap some stickers on it! Every import ive seen at a car show that had stickers on it the owner told me it ran 9s or 10s. Cheap hp in my book!
Re: Quest for the tens. One move at a time... [Re: Baxter61] #587743
01/19/10 10:34 PM
01/19/10 10:34 PM
fresno ca
mikeysmopars Offline
fresno ca
There's always ONE! Thats Great!
I say open those heads and force it out, The converter will think it bigger!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587744
01/19/10 11:03 PM
01/19/10 11:03 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
How heavy is it? I would think that combo should be knocking at the 10 sec zone if it was sorted out.
Re: Quest for the tens. One move at a time... [Re: 440dart] #587745
01/19/10 11:13 PM
01/19/10 11:13 PM
converter at your power range isnt going to make or break it.
you need to port those heads to flow much better to pickup.head flow produces hp.
i picked up .4 from a bogus hemi head flowing 378 to 450 cfm. nothing else.
Re: Quest for the tens. One move at a time... [Re: mikeysmopars] #587746
01/19/10 11:16 PM
01/19/10 11:16 PM
absolutely this is true.
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587747
01/19/10 11:24 PM
01/19/10 11:24 PM
I use to own a NHRA legal stocker that ran 11:20 at 119.MPH and change, it didn't have a adequate fuel delivery system on it to run any faster I found out after I sold it My message is I also agree on getting a better converter. I was offered a TCI on a racer deal back then and had to have it modified by Munsinger several times before it work as well as a Turbo Action. Take the time to call several different GOOD conveter companys and tell them about your combination and see what they recommend. I will bet money that the Turbo Action will be better than most and as good as any of them Your MPH is better than your ET and 60 ft. times, is the car spinning the tires now? If so fix that first before making any other changes
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587748
01/19/10 11:50 PM
01/19/10 11:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Right now your .3 slow based on the MPH, that would
suggest a chassis issue... but it could be a fuel issue
also if your running out on the top end... I would try
to find out whats wrong now
Re: Quest for the tens. One move at a time... [Re: MR_P_BODY] #587749
01/20/10 12:11 AM
01/20/10 12:11 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
sounds like a street car.....I'll bet the converter is the one thing you can change and see big results. Is this a 10" converter...thats the biggest compromise in most street cars (mine included)?
Re: Quest for the tens. One move at a time... [Re: Quicksilver440] #587750
01/20/10 12:17 AM
01/20/10 12:17 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
My vote's for the converter. Get a 8" and you won't regret it.
Re: Quest for the tens. One move at a time... [Re: DblOJoe] #587751
01/20/10 12:24 AM
01/20/10 12:24 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Another converter vote here. And you DONT have to spend $1k on one. I bought a used TCT 9.5" for way less than that , and my car picked up 3 TENTHS--------on just the converter.
Call dynamic / Tct / PTC .
also what is your compression ratio?
those heads and that cam will definitely go 10's with the right combo.
Re: Quest for the tens. One move at a time... [Re: 493_DART] #587752
01/20/10 12:51 AM
01/20/10 12:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We would make a good race as my best et in my 63 Sport Fury is 11.49 @ 116. I have a basic .030 over 440 (446) close to your build but I use 906 heads and the MP .557 cam. Funny as you have 2 more mph then me and a better 60 as my best is 1.57 yet I run as fast an et as you. I run a 9.5 Dynamic converter and love it in my street car. I drive it all the time as I drive it much more then I race it. Your car 60's good for mid 11's and actually should et better with 118 mph. I have to agree that a good converter may help if it is matched to your combo. I would call the converter company you use and let them match one to your combo. I use Luppo's Dynamic but there are alot of good one's out there like PTC , ATI , Turbo Action and so on as you should be able to hit 11.20's now with your mph. Good luck , Ron
Re: Quest for the tens. One move at a time... [Re: 493_DART] #587753
01/20/10 12:51 AM
01/20/10 12:51 AM
Central Valley, CA.
Central Valley, CA.
What does TCT stand for?
