Rim screws on the inside only??? #587403
01/19/10 11:51 AM
01/19/10 11:51 AM
Roseau, MN
1976 Aspen Offline OP
Roseau, MN
I just bought a set of CWI wheels and they are so pretty that I don't wanna clutter them up with rim screws on the outside. Is it OK to just put like eight screws on the inside instead??? It's a 3450 lb. bracket/street car that runs 10.20's with a 1.40 60' leaving off a trans brake. I'm running a M/T 29.5-11.5-15 ET Drag on a 10" rim with tubes. Any info/suggestions are appreciated!!!
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587404
01/19/10 12:00 PM
01/19/10 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not a good move... as/if the tire slips on the outside
it pulls the tire inboard and off the bead
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587405
01/19/10 12:04 PM
01/19/10 12:04 PM
sg66mopar Offline
sg66mopar  Offline
I've never run a tire/wheel combo that small so maybe I'm way off base here but I think you need them on both sides. I wouldn't want the tire slipping on the outside and becoming distorted. I would use 16 rather than 8. I think it looks better and IMO the Cad plated Moroso's don't look too bad.
Re: Rim screws on the inside only??? [Re: MR_P_BODY] #587406
01/19/10 12:04 PM
01/19/10 12:04 PM
Ma
Voluster Offline
Voluster  Offline
Ma
You have 2 options
use the screws on both sides
Or loose the tubes and run Hi tack on beads of the tires
But I wouldn't just do the inside with screws
Re: Rim screws on the inside only??? [Re: Voluster] #587407
01/19/10 12:46 PM
01/19/10 12:46 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I always run tubes in the tires with 8 screws on each side.Was having some problems,was told lose the tubes and screws. I now run my 34.5X17-16 without either.No more problems and I marked the wheel @ the valve stem & they have not moved.
So I say try them without screws or tubes,you can always add them later if needed.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587408
01/19/10 01:33 PM
01/19/10 01:33 PM
I did that several years back on some polish rims, I din't use the tubes though I now don't use tubes or rim screws so its another I wouldn't hesitate to try it, take your shoe polish and mark the rim and tire on the outside by the valve core and watch it for movement, mine move about one inch and stop
Re: Rim screws on the inside only??? [Re: Cab_Burge] #587409
01/19/10 01:44 PM
01/19/10 01:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm on my 6th season with my slicks only screwed on the inside. i was concerned at first about the slick moving on the outside so i used to paint dots on the slick & rim. they never moved. 32x14x15 slicks with 1.3 '60's.
Re: Rim screws on the inside only??? [Re: rebel] #587410
01/19/10 01:53 PM
01/19/10 01:53 PM
sg66mopar Offline
sg66mopar  Offline
Interesting, no screws? Maybe if I ever get new wheels I'll give that a try.
Re: Rim screws on the inside only??? [Re: sg66mopar] #587411
01/19/10 02:01 PM
01/19/10 02:01 PM
PA
moparacer Offline
moparacer  Offline
PA
Man I hate to get involved in a rim screw thread after what I have seen on other boards in the past.
IMO either screw both sides or don't run screws at all.
I dont run them anymore but the quickest I have been in door cars is the 9s.
I think you really ave to be pushing the 60 ft envelope to need them and at that point you mayes well run bead locks if your that fast.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Rim screws on the inside only??? [Re: moparacer] #587412
01/19/10 02:20 PM
01/19/10 02:20 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I feel rim screws are cheap insurance against what "could" happen. And nothing to me says "hot car" better than rim screws on a street car. So I think they are attractive rather then "clutter"
Although I will have to admit after several years of announcing, I have yet to see track cleanup or downtime due to a lack of rim screws.
Re: Rim screws on the inside only??? [Re: ProStDodge] #587413
01/19/10 04:33 PM
01/19/10 04:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have, a Mustang at Dragway42 lost the seal on one side of the tire and went over the guardrail due to having screws on one side of the rim.
340Rick turned me onto some nice screws from Fastenal that have a small head on them and can even be polished.
Re: Rim screws on the inside only??? [Re: ProSport] #587414
01/19/10 05:23 PM
01/19/10 05:23 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I run the screws, but if you have some wheels you don't want screws in and want to be perfectly kosher, run the Radial slicks, don't need any screws in those.
Re: Rim screws on the inside only??? [Re: wyoming] #587415
01/19/10 05:29 PM
01/19/10 05:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
rim screws must also be indexed(straight across from each other) or it may steer the car like Mr P said.
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587416
01/19/10 10:56 PM
01/19/10 10:56 PM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
I ran screws on just 1 side of some 8.5" Convo-Pros before without any issues. This was on 3300 lbs. A body with 28x10 & 29.10" slicks. Car ran mid 10's at time. I was footbraking at time though. Finally went ahead and added screws on outside of rim after hearing & reading of others having problems with just one side "screwed".
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587417
01/19/10 11:18 PM
01/19/10 11:18 PM
ill
dennismopar73 Offline
ill
dont run, never have, never will ,
dont need them
unles youre a top fuel , pro stock car
or something like that no need
do what ever tho
Re: Rim screws on the inside only??? [Re: dennismopar73] #587418
01/20/10 12:50 AM
01/20/10 12:50 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've read that some rims come with bead locks on only one side due to back spacing interfearance,, do you screw the other?
Re: Rim screws on the inside only??? [Re: dennismopar73] #587419
01/20/10 01:05 AM
01/20/10 01:05 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
dont need them
do what ever tho
I'm going to strongly dissagree with this. Perhaps YOU have never needed them, but most guys that run bias-ply slicks with tubes on a car thats 60's under 1.5 are likely dealing with beads moving on the rims. Last year we watched my buddies nova slide the slicks 6" in just 4 runs (10.90's, 60-ing at about 1.5 & out the back door at 125ish) This can be a major safety issue as the tube which is pressurized to the tire will want to move with the tire. The valve-stem in this scenario will be the weak link. You want to blow a tube at 130 mph?? Have at it.... Me?, I'm taking the safe & simple option of adding a couple of screws to the rims.
Re: Rim screws on the inside only??? [Re: StealthWedge67] #587420
01/20/10 01:54 AM
01/20/10 01:54 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I've marked slicks on 13 second cars and seen them move.
That said, I ran without for many years without a problem.
After seeing them move, I like knowing that mine aren't going to anymore
Re: Rim screws on the inside only??? [Re: 1976 Aspen] #587421
01/20/10 02:37 AM
01/20/10 02:37 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you say your new rims are pretty..how are they gonna look if you pull you valve stem out and you hit the wall or hit the guy in the lane next 2 you.
get the screws.
Re: Rim screws on the inside only??? [Re: StealthWedge67] #587422
01/20/10 03:34 AM
01/20/10 03:34 AM
Edmonton alberta Canada
mr. 63plymouth Offline
I agree you dont need them,I run mid 9z on a 10" tire,with sixty fts in the thirties no problem!!!!!!!!!!!!!!
