Valve cover gaskets #587045
01/18/10 09:38 PM
01/18/10 09:38 PM
Sandy, OR
DART67GT Offline OP
DART67GT  Offline OP
Sandy, OR
I tried installing my MP valve covers tonight. I can barely get the bolts started as the covers+gaskets are too thick. I'm using the felpro rubber gaskets and ARP bolts. Has anyone else encountered this problem, and are there thinner gaskets that would help?
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: Valve cover gaskets [Re: DART67GT] #587046
01/18/10 10:55 PM
01/18/10 10:55 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Do you have the bolts for cast aluminum covers? They tend to be longer than bolts designed for stamped covers.
I had to get the longer bolts when I put my cast covers on.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Valve cover gaskets [Re: wingman] #587047
01/18/10 11:10 PM
01/18/10 11:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ditto on needing longer bolts or studs. IIRC, thread size is 1/4-20. Depending on your intake, sometimes there's also interference at the runners.
Re: Valve cover gaskets [Re: topside] #587048
01/18/10 11:24 PM
01/18/10 11:24 PM
what they said, some longer bolts w the head design that suits you
Re: Valve cover gaskets [Re: RapidRobert] #587049
01/18/10 11:49 PM
01/18/10 11:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used allen head cap screws in mine. Much eaiser than using a socket wrench.
