Removing Hard Blok? #58616
05/15/08 12:02 PM
05/15/08 12:02 PM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
Anybody ever have any success getting Hard Blok water jacket filler out of a block? Any magic method? I don't want to junk the block.
Re: Removing Hard Blok? [Re: Desmond] #58617
05/15/08 07:24 PM
05/15/08 07:24 PM
under the hood
A47 Offline
A47  Offline
under the hood
there is a type of acid ..that has been used .. think its called muric acid . but don't quote me on it . takes a long time though ..sure it was mentioned in a thread on here a while a go
one of the Dudes on the race only forum will know i'm thinking
Re: Removing Hard Blok? [Re: A47] #58618
05/15/08 08:24 PM
05/15/08 08:24 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Be careful, Muriatic Acid + Aluminum = bomb
Re: Removing Hard Blok? [Re: Desmond] #58619
05/15/08 09:16 PM
05/15/08 09:16 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Frankly, if it was done properly, it will be extremely difficult, if not impossible. And I would worry that if you managed to get it to break up, you will be hard pressed to get out all of the pcs., which will make a mess of your cooling system.
Unless it's the original motor to your car, sell it to a racer and move on.
Re: Removing Hard Blok? [Re: HPMike] #58620
05/15/08 09:28 PM
05/15/08 09:28 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
It's not worth the hassle or the risk.
Re: Removing Hard Blok? [Re: Desmond] #58621
05/17/08 05:41 PM
05/17/08 05:41 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Forget it
Re: Removing Hard Blok? [Re: Michael] #58622
05/21/08 06:39 PM
05/21/08 06:39 PM
Canada
RobR Offline
RobR  Offline
Canada
You can't take it out...
Re: Removing Hard Blok? [Re: RobR] #58623
05/22/08 02:26 PM
05/22/08 02:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
one could get it all out if they bored all the cylinders out till they were gone , chipped it out , the resleeved the entire block ...
but i doubt thats hardly worth the effort or the cost unless its your matching numbers block ...
