Voltage Regulator problem (1970 E-Body) ??
#585834
01/17/10 06:47 PM
01/17/10 06:47 PM
Posts: 157 California
dg_dodge
California
Hi All, I posted last week about a No-start/No-spark problem I was having on my 1970 Challenger (w/ Mopar electronic ignition). With the fantastic help and lessons I got from the great people here I was able to determine that it was the ECU that went bad on me. THANK YOU very much for all the help on that one! I picked up a standard OEM (blue) ECU box at a local parts place (figuring I could use it as a spare after I order a new Orange one). I put it in and it fired right up and runs really strong. Then, just when I thought I was done with the gremlins (this car has not had an electrical issue before in all the time I've had it), I noticed as I was warming it up that the Ammeter at idle was fine (a tad over the middle), but when I gave it some gas (to say 1500 rpms or higher), the needle pegged to the far right of the meter. Letting off the gas, it comes back to where it should be. This never acted this way prior to last week and the ECU failure/replacement. I had charged the battery up fully after all the testing for the ECU stuff, so it couldn't have needed the charging it was getting.. So, I'm wondering now .. (1) Does it sound like the Voltage Regulator also took the opportunity to give out on me? (2) If so, is this common for both components to go bad in unison? (3) Is the fact I'm running the blue (oem) ecu unit rather than an Orange, a possible cause (since it's a Mopar performance distributor)? Any insight or ideas would be greatly apprecated!! Thanks again!
Re: Voltage Regulator problem (1970 E-Body) ??
[Re: dg_dodge]
#585835
01/17/10 07:18 PM
01/17/10 07:18 PM
RapidRobert
(1) yes but 1st take it off/clean it's base/ground. (2) no but when it happens that way it will test your diagnostic abilities (3) not at all. I'd get a new electronic VR & I think you'll be good
[Re: dg_dodge]
#585837
01/17/10 10:52 PM
01/17/10 10:52 PM
RapidRobert
You have the flat one w the triangle connector? To my knowledge the flat ones are the same ex the blue MP one is a higher "constant voltage" type that is supposed to be a race only item but people have used it on the street w no issues. Any possibility you could easily post pics of the 2 and any description given along with them.
[Re: dg_dodge]
#585840
01/18/10 04:03 PM
01/18/10 04:03 PM
RapidRobert
the're the same ex the diff color on the triangle surround most likely denotes that it is a higher voltage unit. I think if you grab the $15 one you'll be fine.
[Re: dg_dodge]
#585843
01/18/10 04:27 PM
01/18/10 04:27 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Thanks for the quick reply Robert! Ok, I'll clean things up and put a new Voltage Regulator in there in a few days when I get over to the car again.
From scouting the online parts guide for my local chain, looks like Chrysler used the same unit from 70-77 (no difference between elec. ign vs. points ign) so this should be easy to come by. Funny though, they list a basic voltage regulator for around $15 (BWD brand # R296P) and another for almost 3x that price (BWD brand # R296). If anyone thinks one might be better than the other, please let me know.
Thanks much!
The cheaper one has mechanical points, and the more expensive one has a transistor switcher. The transistor version is more reliable in the long run. Also be sure to sand off the paint or powder coating on the rear of the voltage regulator, this is crucial for a good ground.
Just my $0.01..
[Re: Sinitro]
#585844
01/18/10 04:32 PM
01/18/10 04:32 PM
RapidRobert
Sinitro your not saying the cheaper flat one in the pic is points you mean the $15 one that they are selling is the old style mechanical unit not one of the 2 shown in the pics?
[Re: RapidRobert]
#585845
01/18/10 07:30 PM
01/18/10 07:30 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
The old mechanical ones only work with single terminal field alternators used up through 69.
[Re: dg_dodge]
#585846
01/19/10 03:14 AM
01/19/10 03:14 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
It sounds like the alternator is charging with full field current. This could be a bad voltage regulator, or a short in the wiring that goes to the voltage regulator. #1. Unplug the triangle connector at the voltage regulator, start the car and rev the engine to verify the alternator is NOT charging. #1a. If in above test, No charging is observed, replace the voltage regularor. #2. If in the above test the alternator is still overcharging, disconnect the field wire going to the regulator and repeat the test in step #1. #2a. If No charging observed, check wire for short to ground. #3. If alternator is still overcharging, there is a short at the alternator. Usually this is just a short at the alternator brush holder.
The $15 voltage regulator is fine if it is the bad part.
[Re: dg_dodge]
#585848
01/24/10 08:37 PM
01/24/10 08:37 PM
dg_dodge
California
Update on this one - it was the voltage regulator that was going bad .. I replaced it with the new $15 one and charging is back to normal now. Much thanks for the help! One more very newbie question -- when I went to mount the new regulator back on the firewall, one of the mounting bolts still feels loose (spins if I try to tighten it more). I didn't overtighten it to begin with and the holes don't appear to be threaded. So, my question is - how to deal with spinning mounting bolts in the firewall in these situations? I don't think I can get behind there to put a nut on the back, right??? Do I need to go up a size in bolts (It's a 7/16" currently) or are there insider tricks for this ? Thanks!
[Re: BDW]
#585850
01/24/10 10:30 PM
01/24/10 10:30 PM
Posts: 15,491 the boonies
aarcuda
the boonies
gotta make the hole smaller. can you tap the flared hole back flat? another trick is to stick some wire in the hole to take up space. ruin a sparate ground to the case of the VR and you wont have to worry about the ground connection anymore
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
