Dome light #585144
01/17/10 10:23 AM
01/17/10 10:23 AM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Why is my dome light bulb keep burning out?
I have replaced it 2 times in the last few months and it just went again?
Old bulbs or bad wire maybe?
Re: Dome light [Re: DAMOPARS] #585145
01/17/10 10:24 AM
01/17/10 10:24 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
check the ground.
also check to make sure it's OFF when it should be.
Re: Dome light [Re: RodStRace] #585146
01/17/10 10:26 AM
01/17/10 10:26 AM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
The ground at the light?
Re: Dome light [Re: DAMOPARS] #585147
01/17/10 12:30 PM
01/17/10 12:30 PM
Probably just a coincidence but as said I'd just visually check the socket real quick and open both doors & a quick check there also on the grounding plungers & see if anything is loose that might be inadvertently grounding the circuit part time.
