Help--Exhaust Manifold bolts won't stay tight #584298
01/16/10 03:25 PM
01/16/10 03:25 PM
St. Louis, Mo
3
318 Stroker Offline OP
St. Louis, Mo
I have an Eddy headed 318 with the 340 Hi-po exhaust manifolds. The bolts loosen every time I drive it. Is it Ok to use Lock-Tite for this application? That's the only solution I can think of to solve the problem.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584299
01/16/10 03:46 PM
01/16/10 03:46 PM
California
6superbee9 Offline
6superbee9  Offline
California
If I was desparate I'd try lock washers (the ones that have the split in them). See what the more experienced guys come up with.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 6superbee9] #584300
01/16/10 03:50 PM
01/16/10 03:50 PM
St. Louis, Mo
3
St. Louis, Mo
Yes, I am desperate. Driving me crazy. I had a hodge-podge of manifold bolts in there, and just recently purchased the correct set of fasteners, with the combination of sleeve-bolts, studs w/nuts, bolts, and cupped washers, and I'm still having the problem.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584301
01/16/10 03:51 PM
01/16/10 03:51 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
I would NOT try lock-tite ... if the bolts/studs ever have to be removed ... you could mess-up the head. I would try some black or gold RTV and let it set-up well before using.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: BeEtLeJuIcE !] #584302
01/16/10 03:53 PM
01/16/10 03:53 PM
St. Louis, Mo
3
St. Louis, Mo
That's kinda what I was thinking, and that's why I asked before doing it. On the first set of fasteners I had lock washers, and that didn't work either.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584303
01/16/10 03:55 PM
01/16/10 03:55 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Yeah lock tite is fine just use the right type for the temp range, you could also try studs glued in with nuts that have locking threads.
I had a Toyota that would do the same thing, I ended up running studs with locktite and staked around the holes after the studs were in place to tighten them in more, I used nuts with locking threads too, they have waves in the treads so they bite into the threads of the stud.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: MoparJoe] #584304
01/16/10 11:15 PM
01/16/10 11:15 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
Anyone else had this problem? Is it from the expansion rates on the aluminum heads? I just put mine back together with Eddy heads and had my 340 Hi-po manifolds Jet-Hot coated, hoping I don't end up with this problem. Totally-Stainless carries a washer that is supposed to be vibration proof, but they are imported from Sweden and cost over $3 each, and you can't use any other spacers or washers with them unless you put one on each side of the spacer- could get pricey..
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584305
01/16/10 11:35 PM
01/16/10 11:35 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I use Permatex anti-seize lubricant #133K on my aluminum heads. You might also want to check your exhaust hangers and make sure the exhaust system isn't flopping around.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: krw71ragtop] #584306
01/16/10 11:59 PM
01/16/10 11:59 PM
St. Louis, Mo
3
St. Louis, Mo
I have a tti system and everything is tight. I idled the car for 15 minutes the last two nights, to warm it up, and I had some looseness to the fasteners. As the previous poster, "donbarnes" said, I think it has something to do with the different expansion rates. I can't think of any other solution besides using anti-seize.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584307
01/17/10 12:20 AM
01/17/10 12:20 AM
St. Louis, Mo
3
St. Louis, Mo
I mentioned Lock-Tite in my original post, and anti-seize has also been mentioned. Does anti-seize have "locking" properties, or strictly "anti-seize" properties?
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584308
01/17/10 12:27 AM
01/17/10 12:27 AM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
You should MOST DEFINATELY be using anti-sieze on the threads. It doesn't make your spark plugs back out so it won't make your fasteners back out. (you are using it on your plugs right?) Anti-sieze is way cheaper than having to pull your heads and have them tapped for helicoils and replacing the head gaskets. Use it any time you use a steel fastener on an aluminum part.
Split type lock washers should stop the loosening. Studs are awesome because they go from course thread to fine thread which has better torque retention and vibration resistence. If you want the ultimate in torque retention you could always get bolts drilled for safety wire like the NASCAR and other racing guys do. If you do it right, the bolts CAN NOT MOVE. If your scared of lockwire then you can try Stage 8's locking bolts. They're pricey but they can't back out unless you disassemble them.
You have options. I like the mechanically locking hardware around high heat. Metal won't melt, plastic and chemicals will.
Try some new Grade 8 bolts and split lock washers first. That shouldn't cost more than $10.
-1967 Belvedere II 440/4speed
Re: Help--Exhaust Manifold bolts won't stay tight [Re: MACDiesel] #584309
01/17/10 12:42 AM
01/17/10 12:42 AM
St. Louis, Mo
3
St. Louis, Mo
Thanks for the advise. Yes, I am using anti-seize on the spark plugs.
I just spent good money buying the correct factory-style fastener kit for the hi-po manifolds. As I mentioned, it is a combination of sleeve-bolts, studs w/nuts, and bolts. I'm thinking of giving the anti-seize a try first, and if that doesn't work, anti-seize and lock-washers. I was using lock washers previously, and still had problems.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584310
01/17/10 01:41 AM
01/17/10 01:41 AM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
The guy that mentioned different expansion rates nailed it. A lot of guys helicoil all the threaded holes right from the get go. You could try selling that original kit and get those Stage 8's. They have a e-clip groove cut into the wrench flats and locking tangs that slip over the bolt heads. The locking tangs have a 12 point hole so they can be positioned properly on the bolt head. Then you lock it in place with the e-clip. If the bolt loosens the tang will hit the manifold and stop the bolt from turning. So it can't loosen more than 1/12 turn. Pretty darned fail safe.
http://www.stage8.com/products_lhb.html
Safety wire works too.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584311
01/17/10 01:41 AM
01/17/10 01:41 AM
Florida STAYcation
Florida STAYcation
Hey 318 .. using anti-seize on these will make the problem WORSE.
I still say use a high-temp RTV and let it cure WELL before using.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584312
01/17/10 02:15 AM
01/17/10 02:15 AM
Knoxville,Md
70redbee Offline
70redbee  Offline
Knoxville,Md
If you have studs and nuts,try double nutting to keep them tight.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 70redbee] #584313
01/17/10 09:07 AM
01/17/10 09:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use studs in my aluminum heads except for 1 or 2 that wont fit with headers.I use antisieze on them.2 years of street driving and they never come loose.I use the larger thick flat washers on mine also.Rocky
Chrysler Firepower
Re: Help--Exhaust Manifold bolts won't stay tight [Re: 318 Stroker] #584314
01/17/10 10:16 PM
01/17/10 10:16 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
How did you get them to fit? you must have done a ton of grinding to the heads.
I have a pair of Edelbrock closed chambers (04 vintage I think) and wanted to install my H/P manifolds, but no go unless I did a whole bunch of grinding.
Went with TTIs that slipped in easier then iron.
Never a leak or losen up.
Re: Help--Exhaust Manifold bolts won't stay tight [Re: boydsdodge] #584315
01/18/10 11:11 AM
01/18/10 11:11 AM
St. Louis, Mo
3
St. Louis, Mo
Yep, the driver side required grinding on the head. I had the motor built by a professional Mopar engine builder, and when I picked up the motor, I noticed the ground head.
Edelbrock claims that the heads are bolt-on, but you open up a whole can of worms when you use them. The heads are longer than stock, so you have to re-engineer the alternator bracket, as well as the above mentioned manifold problem.
The heads are great, performance-wise, but I'm almost wishing that I had used stock iron heads instead.
