'70 Road Runner White & Black Interior Questions #583928
01/16/10 03:54 AM
01/16/10 03:54 AM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Using THIS PAGE as my guide, I see the seats, door panels, and rear quarter panels will all be white with the carpet, dash, and headliner done in black.
Kick panels should be black, too, correct? Black package tray, sail sail panels on the C-pillars, and seat belts, also?
Using THIS PAGE as my guide for the door panels, it appears the door panel wraps over the top edge of the door and no paint shows at the top. Is that correct?
TIA
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583929
01/16/10 07:04 AM
01/16/10 07:04 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Door panels don't cover top of door, that's painted. All else seems corect.
Re: '70 Road Runner White & Black Interior Questions [Re: Bull1tt] #583930
01/16/10 10:28 AM
01/16/10 10:28 AM
okla.
O
okie Offline
okie  Offline
O
okla.
On mine the headliner is white too. The inside of the doors and back trim is painted white. The dash, package tray and the front winshield trim is black. The carpet and kick panels are also black. This is the way mine was originaly. Good Luck! Ronnie
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583931
01/16/10 11:11 AM
01/16/10 11:11 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The headliner and mouldings to the side of it should be white along with the upper rear window trim.
Re: '70 Road Runner White & Black Interior Questions [Re: hemi70se] #583932
01/16/10 11:39 AM
01/16/10 11:39 AM
Milwaukee, WI
Milwaukee, WI
Thank you.
This was the only pic of '70 RR with a white & black interior I could find online, and it does appear the top edge of the door is painted black:
This one, however, appears to have door panels which wrap the top edge of the door:
Is this full height door panel part of the Decor Group option?
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583933
01/16/10 11:39 AM
01/16/10 11:39 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Carpet, dash, A pillars, kick panels, console and package tray should be black. Everything else white.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: '70 Road Runner White & Black Interior Questions [Re: 70gtx440dana] #583934
01/16/10 11:41 AM
01/16/10 11:41 AM
Lansing, MI
Lansing, MI
Another picture...
Re: '70 Road Runner White & Black Interior Questions [Re: 70gtx440dana] #583935
01/16/10 11:45 AM
01/16/10 11:45 AM
Lansing, MI
Lansing, MI
Another....
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583936
01/16/10 12:19 PM
01/16/10 12:19 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Thank you.
I see no Door Panel to the top of the edge of the door, in fact it looks like it's just painted door metal, no trim visible.
Am I missing something here? I thought only Chargers had the upper door trim?
Somebody school me on this if i'm wrong please.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: '70 Road Runner White & Black Interior Questions [Re: Hoof Hearted] #583937
01/16/10 01:50 PM
01/16/10 01:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The only '68-'70 B-body with any upholstery on the upper door frames is the Charger. Zero-None-no way on a Plymouth B-body '68-'70. White interiors '69-'70 had the upper door frames & quarter metal panels painted white.
Chargers had white headliners with white interiors, Plymouth bounced back & forth. My '69 RR White Decor interior had a black headliner. Dash, column, carpet, kick panels, package tray & seatbelts black.
Re: '70 Road Runner White & Black Interior Questions [Re: topside] #583938
01/16/10 09:28 PM
01/16/10 09:28 PM
Milwaukee, WI
Milwaukee, WI
Ok, so the area outlined in pink in my attached picture is metal, correct? And the pink outlined piece is a separate piece from the inner door shell itself?
And the yellow line indicated the topmost edge of the door panel, correct?
Thanks for the pics.
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583939
01/16/10 09:36 PM
01/16/10 09:36 PM
Lansing, MI
Lansing, MI
For a 70 road runner the area you outlined in pink is part of the door shell and will look just like the full size picture you posted above. One small hole for access to allen bolt that holds window channel in place. May have another hole for remote mirror if so equipped. PS door only has the one small hole as well. The rear piece for back seat area below quarter window is a seperate piece that screws on.
Re: '70 Road Runner White & Black Interior Questions [Re: 70gtx440dana] #583940
01/16/10 10:32 PM
01/16/10 10:32 PM
Milwaukee, WI
Milwaukee, WI
Good info, thanks.
Re: '70 Road Runner White & Black Interior Questions [Re: In_The_Pink] #583941
01/16/10 11:32 PM
01/16/10 11:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
To take it a bit further, the chrome molding at the top of the vinyl interior trim panel finishes the edge of the trim panel & is attached by phillips screws; you have to remove the trim panel to access them. The interior color breaks under the weatherstrip; you'll find a masking line there. The bottom metal area, below the trim panel, was the same color as the top metal part.
