Big Block Cordoba #583226
01/15/10 11:31 AM
01/15/10 11:31 AM
SE MI
Duster499 Offline OP
SE MI
What issues might I encounter swapping a 400 motor into a 360 Cordoba? Is the K member the same for both. Do I just need to change motor mounts? How about the tranny? Has anybody done such a foolish thing?
Re: Big Block Cordoba [Re: Duster499] #583227
01/15/10 11:43 AM
01/15/10 11:43 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
I know that the Doba came with a 400 up untill 78. I think the block is considered a big block so the tranny will need to be one as well. As for the K-member I'm not sure but there are mounts out there to use a BB where a SB was without changing the member. You will also need a drive shaft as the trany lengths are different.
1979 Chrysler 300 1968 Barracuda project
Re: Big Block Cordoba [Re: LS-300] #583228
01/15/10 11:50 AM
01/15/10 11:50 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
What he said... The isolated k frame used a different piece between small and big blocks..The easiest/cheapest swap would be to find an original BB car and snag the parts you'd need...Check out this thread I just posted on..Same deal for you but you'll need the factory manifolds also... link
Re: Big Block Cordoba [Re: screamindriver] #583229
01/15/10 05:36 PM
01/15/10 05:36 PM
The June '92 mopar action has an Eberg comprehensive article on a 440 F body swap.
Re: Big Block Cordoba [Re: RapidRobert] #583230
01/15/10 06:48 PM
01/15/10 06:48 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
If you're interested I have a 40,000 mile '77 400 4bbl Cordoba I'd sell you reasonable enough.
Re: Big Block Cordoba [Re: slantzilla] #583231
01/16/10 01:40 AM
01/16/10 01:40 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
In addition to the big block K frame and brackets you must use the matching oil pan and pick up. The common 402 style pans will not fit...
And all the other stuff like radiator, wiring, exhaust,etc....really requires a donor vehicle..
