'05 Hemi Ram rough idle and stalling. #58292
05/12/08 08:29 AM
05/12/08 08:29 AM
Atlanta Indiana
Dave Watt Offline OP
Atlanta Indiana
A co-worker has an '05 Hemi Ram that's idle is jumpy and sometimes stalls (dies). There aren't any fault codes in the computer for the dealer to help diagnose. One dealer did replace the throttle body which helped the stalling but it still has a jumpy idle.
Anyone hear of this problem?
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58293
05/12/08 12:47 PM
05/12/08 12:47 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
EGR valve maybe. They are a bit of a problem on the Hemi's, although you usually get a fault code. They are pretty cheap and easy to install. Ask me how I know.
Re: '05 Hemi Ram rough idle and stalling. [Re: RalleyA12] #58294
05/12/08 01:35 PM
05/12/08 01:35 PM
Atlanta Indiana
Atlanta Indiana
Ask me how I know.
OK, how do you know?
I hadn't thought of an EGR valve, but without an error code he would just be taking a chance?
Thanks,
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58295
05/13/08 01:11 PM
05/13/08 01:11 PM
Atlanta Indiana
Atlanta Indiana
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58296
05/13/08 01:16 PM
05/13/08 01:16 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
This may sound stupid to you but its happened to me on more than one occasion. Check the battery! Low voltage will make these newer model Dodges act very Crazy! I had a truck doing almost that same thing. Changed the battery and it went away. It may not work for your friend but its worth a try....
Re: '05 Hemi Ram rough idle and stalling. [Re: silverfish] #58297
05/13/08 01:56 PM
05/13/08 01:56 PM
Atlanta Indiana
Atlanta Indiana
That's an interesting suggestion. Most of his problems are right after starting it. Drops it in gear and may make it to the edge of the parking lot or want to die right away. This is something else for him to check in to.
Thanks.
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58298
05/13/08 11:35 PM
05/13/08 11:35 PM
colorado
9
929lamasters Offline
colorado
I had this same Problem on my 99 dodge ram not a Hemi but it was the TPS but my got to the point of not even wanting to idle but up intell that point acted the same
Re: '05 Hemi Ram rough idle and stalling. [Re: 929lamasters] #58299
05/17/08 06:42 AM
05/17/08 06:42 AM
Atlanta Indiana
Atlanta Indiana
We have a spare EGR valve to try, he can't find where it is on the truck. Anyone know where to find it?
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58300
05/17/08 06:53 AM
05/17/08 06:53 AM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
try cleaning the Idle air controller. On my truck when it starts stalling and has bad idle I clean that sensor with brake cleaner and problem goes away. do not push on the punger I just remove the valve and spray the cleaner on and let the carbon drip off.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: '05 Hemi Ram rough idle and stalling. [Re: blk00rt] #58301
05/17/08 09:36 AM
05/17/08 09:36 AM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
not a dodge, but my 01 chevy truck did this exact thing and it was the throttle position sensor. I dident even buy a new one I just sprayed some electrical contact cleaner in the connectors and it stopped it.
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58302
05/19/08 02:01 PM
05/19/08 02:01 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
It's on the front of the passenger side head. Get the battery out of the way and you should be able to see it.
Re: '05 Hemi Ram rough idle and stalling. [Re: RalleyA12] #58303
05/19/08 02:13 PM
05/19/08 02:13 PM
places
79powerwagon Offline
places
Is your cat plugged or defective?
Re: '05 Hemi Ram rough idle and stalling. [Re: RalleyA12] #58304
05/23/08 12:00 PM
05/23/08 12:00 PM
Atlanta Indiana
Atlanta Indiana
Well, I went out at lunchtime and looked at the '05 Ram in question. The battery is on the drivers side. The front of the passenger head has a two bolt blockoff plate. I'm very confused now. This is a 3/4 ton.
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58305
05/23/08 05:40 PM
05/23/08 05:40 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i would think it would be the IAC motor?brad watt
Re: '05 Hemi Ram rough idle and stalling. [Re: RalleyA12] #58306
05/23/08 07:02 PM
05/23/08 07:02 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
That is going to be a interesting trick...Since the battery is on the Driver side AND....a `05 2500 5.7 dosen`t have a EGR valve
Or for that matter a IAC either
Ask me how I know.
Rick
Re: '05 Hemi Ram rough idle and stalling. [Re: Dave Watt] #58307
03/13/12 02:06 AM
03/13/12 02:06 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
my 2004 hemi ram stalls ides high then low.. has new mopar brand EGR and 1 year old MOPAR battery. removed and cleaned TB too.
still doing it
Re: '05 Hemi Ram rough idle and stalling. [Re: 70blackfish] #58308
03/13/12 02:33 AM
03/13/12 02:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Does it have a steady miss at all as normally it would set a code if it did but if the battery has been disconnected or real low it may have lost the crank sensor addaptive counter and until it relearns it the missfire counter wont count or set a code. I dont think its the IAC (idle air control) motor as you have to remember the IAC is a stepper motor on your truck and if it is changing the idle then that means the PCM is working the IAC and that means something is telling the PCM to work the IAC. The IAC alone wont change the idle untill the PCM tells it to. A bad TPS will cause it as the PCM will think you step on the gas and the TPS volts will change so the PCM will flare the idle to componsate. Could also be leaking EGR valve. Do you have a scanner you can put on it ? Ron
