Re: '05 Hemi Ram rough idle and stalling.
[Re: RalleyA12]
#58294
05/12/08 01:35 PM
05/12/08 01:35 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Ask me how I know.
OK, how do you know? I hadn't thought of an EGR valve, but without an error code he would just be taking a chance? Thanks, Dave
[Re: Dave Watt]
#58300
05/17/08 06:53 AM
05/17/08 06:53 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
try cleaning the Idle air controller. On my truck when it starts stalling and has bad idle I clean that sensor with brake cleaner and problem goes away. do not push on the punger I just remove the valve and spray the cleaner on and let the carbon drip off.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: Dave Watt]
#58302
05/19/08 02:01 PM
05/19/08 02:01 PM
Posts: 535 Marilla, New York
RalleyA12
Marilla, New York
We have a spare EGR valve to try, he can't find where it is on the truck. Anyone know where to find it?
It's on the front of the passenger side head. Get the battery out of the way and you should be able to see it.
[Re: RalleyA12]
#58306
05/23/08 07:02 PM
05/23/08 07:02 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
That is going to be a interesting trick...Since the battery is on the Driver side AND....a `05 2500 5.7 dosen`t have a EGR valve
Or for that matter a IAC either
Ask me how I know.
Rick
[Re: Dave Watt]
#58307
03/13/12 02:06 AM
03/13/12 02:06 AM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
my 2004 hemi ram stalls ides high then low.. has new mopar brand EGR and 1 year old MOPAR battery. removed and cleaned TB too. still doing it
[Re: 70blackfish]
#58308
03/13/12 02:33 AM
03/13/12 02:33 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Does it have a steady miss at all as normally it would set a code if it did but if the battery has been disconnected or real low it may have lost the crank sensor addaptive counter and until it relearns it the missfire counter wont count or set a code. I dont think its the IAC (idle air control) motor as you have to remember the IAC is a stepper motor on your truck and if it is changing the idle then that means the PCM is working the IAC and that means something is telling the PCM to work the IAC. The IAC alone wont change the idle untill the PCM tells it to. A bad TPS will cause it as the PCM will think you step on the gas and the TPS volts will change so the PCM will flare the idle to componsate. Could also be leaking EGR valve. Do you have a scanner you can put on it ? Ron
