Big difference going from 3.23's to 3.73's?
#582491
01/14/10 07:01 PM
01/14/10 07:01 PM
Posts: 1,978 Moncton, New Brunswick
hemidart1
I'm thinking of changing the gears in my '67 Charger(a stock 383 hp re-build). Right now I have a 3.23 open rear with 28 inch tall tires and you can guess how sluggish it is. I'd like to have a bit more umph and not have to cruise around town at idle. So I'm thinking a 3.73 posi.
Question is -will I notice any big difference?
1967 Hemi GTX 1969 Chrysler 300
Re: Big difference going from 3.23's to 3.73's?
[Re: hemidart1]
#582492
01/14/10 07:15 PM
01/14/10 07:15 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
yes, will noticeable.
you'll have aprox 15% more RPMs at same speed, and also some torque increasing
[Re: 440newport]
#582495
01/14/10 07:39 PM
01/14/10 07:39 PM
NachoRT74
Valencia, España
well I'm saying will be noticeable, not BIIIIIG noticeable.
I jumped from 3.23 to 3.55 and I noticed.
500 RPMs increase is on certain speed not all the speed ratio... is 15% diff
[Re: Junky]
#582497
01/14/10 07:58 PM
01/14/10 07:58 PM
hemidart1
it's more that I'd like to get it from idle to a usable rpm a little quicker.
[Re: terzmo]
#582499
01/14/10 08:16 PM
01/14/10 08:16 PM
Posts: 233 vashon island washington
hunterstroble
I swapped from 3.23 to 3.91's i gained 2 tenths in the quarter and an extraa 500 rpm crusing, two tenths aern't worth it to me, i'm going back. do what the other people said and get a mild stall converter. Also i'd disconnect the vacuum advance and run 36 degrees total timing, if it were me. But everyones car is different.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
[Re: NachoRT74]
#582501
01/14/10 08:29 PM
01/14/10 08:29 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
My butt dyno also noticed the difference 'tween 3.23 and 3.55. Going from 3.23 to 3.73 would definately make a noticable difference, but you're also more likely to notice deficiencies in the top end (assuming they are there) more cause you'll rev faster and spend more time there.
I even felt the difference going from 2.76 to 2.94 in a Volare.
[Re: hemidart1]
#582502
01/14/10 08:30 PM
01/14/10 08:30 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
Swap to a 26" tire and see if you like it. If it's a stock build you may be working away from the torque band. Swapping on a set of tires is a quicker and cheaper solution to test it out.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: Noblewk]
#582503
01/14/10 09:22 PM
01/14/10 09:22 PM
hemidart1
I actually checked the numbers and I have a 2.94 rear end-so the jump to even 3.55's would be a welcome!
[Re: hemidart1]
#582507
01/15/10 08:47 AM
01/15/10 08:47 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I made two swaps, 3:55's to 3:91's and also from a stock torque converter to a Turbo Action #17805ST (3500) and the larger gain of the two swaps was the conveter. I started with 3:91's than went to the 3:55's and then went back to the 3:91's with a 27" rear tire. I don't mind the 3300rpms at 65mph and the off the line grunt was better with the 3:91's. I would suggest trying the converter swap first. If you go this route, I would suggest jumping up into the 32-3500rpm range.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: 440newport]
#582509
01/15/10 09:35 AM
01/15/10 09:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Not really no. I went from 3.23's to 3.91's and it certainly gets off the line better, but it wasn't a huge difference. The biggest thing I noticed was the extra 500rpm on the highway.
don't know why you didn't notice. Yes 3.23 to 3.73 will be a big improvement. I had a 69 383 charger w. 3.23's went thru the traps in 2nd (14.20) when I swapped in the 3.91's I got to use all 3 gears and dropped to 13.68.
